When I ran a job with written in OpenACC, an error has occurred.
Could you let me know why I got the error message ?
And then I set the environment variable “PGI_ACC_BUFFERSIZE” and reduce the value to 4M.
No error occurred.
Could you let me know why I did NOT get the error message when I set the environment variable “PGI_ACC_BUFFERSIZE” ?
Here is the error message of standard output.
total/free CUDA memory: 1011023872/998965248
Present table dump for device[1]: NVIDIA Tesla GPU 0, compute capability 2.1
host:0x602d00 device:0x400540000 size:512 presentcount:1+0 line:11 name:a
allocated block device:0x400540000 size:512 thread:1
call to cuMemHostAlloc returned error 2: Out of memory
And here is the source code. It is very simple.
program async_test
implicit none
integer(kind=4),parameter :: n = 128
integer(kind=4),dimension(n) :: a
integer(kind=4) :: i
do i = 1,n
a(i) = i
end do
!$acc data create(a(:))
do i = 1,n
!$acc update device(a(i:i)) async(i)
end do
!$acc wait
!$acc end data
end program async_test
Here is the result of “deviceQuery”.
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: “GeForce GT 610”
CUDA Driver Version / Runtime Version 8.0 / 7.5
CUDA Capability Major/Minor version number: 2.1
Total amount of global memory: 964 MBytes (1011023872 bytes)
( 1) Multiprocessors, ( 48) CUDA Cores/MP: 48 CUDA Cores
GPU Max Clock rate: 1620 MHz (1.62 GHz)
Memory Clock rate: 500 Mhz
Memory Bus Width: 64-bit
L2 Cache Size: 65536 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536, 65535), 3D=(2048, 2048, 2048)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 32768
Warp size: 32
Maximum number of threads per multiprocessor: 1536
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (65535, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 1 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 11 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 8.0, CUDA Runtime Version = 7.5, NumDevs = 1, Device0 = GeForce GT 610
Result = PASS
When I compiled a job with written in OpenACC, I used the PGI compiler.
% pgfortran -V
pgfortran 16.5-0 64-bit target on x86-64 Linux -tp p7
The Portland Group - PGI Compilers and Tools
Copyright (c) 2016, NVIDIA CORPORATION. All rights reserved
