If I have different 2 different(or same) GPU, which one will be chosen when I compile OpenACC with PGI?Stronger calculation ability or random.
Could I assign the GPU and How(for example)?
best,
Jackie
best,
Jackie
Yes, you can assign a specific GPU.
run pgaccelinfo
to determine the GPU numbers (0,1)
or call
ierr=cudaGetDeviceCount(numdev)
from within the program
Use OpenMP (not OpenACC) to run two threads
simultaneously. each OpenMP thread on the CPU will assign a GPU and
then run an OpenACC from each thread.
ierr = cudaSetDevice(mydev)
Now you have two GPUs running an OpenACC program
simultaneously.
has an example.
