OpenCV CUDA on AGX XAVIER
Hello everyone,
As you know, opencv 4.4.1 that comes with jetpack is not supported by CUDA.
Therefore, ı want to install the current version of OpenCV supported by CUDA. Does anyone have a method on how to do this ?
I installed opencv 4.5.1. but when i run a simple application i get this error
Hi mehmetoglufrat,
Do you check that you read this image successfully? Maybe you can use
print(img)
to check your img.
