transform.cpp
transform::transform(...) {
setupPyFunc();
int transform::setupPyFunc()
Py_Initialize();
if(!Py_IsInitialized())
return ERROR_PYTHON_INIT_FAILED;
// Relocate the working path of Python
QString pyFuncPath = QString("sys.path.append(
</li>
<li> transform.h
#include <python3.5m/Python.h>
class transform: public QDockWidget
Q_OBJECT
public:
transform(…);
~transform();
private:
PyObject *mPyModule = nullptr;
PyObject *mPyFuncDict= nullptr;
PyObject *mPyFunc = nullptr;
</li>
<li> processimage.py
-- coding: utf-8 --
import numpy as np
import numpy.matlib
import matplotlib.pyplot as plt
import os
from array import array
import numpy.fft as fft
import cv2
import time
from PIL import Image
import re
def main(processFolderName = None):
if processFolderName is None:
dirfolder = r’/home/nvidia/Workspace/project/v2-Debug/RawData0’
else:
dirfolder = r’/home/nvidia/Workspace/project/v2-Debug/'+processFolderName
os.chdir(dirfolder) # go to the dir
dirs = os.listdir(dirfolder) # list all the folders in dirfolder
img_SubBgr = np.round((DDD+ abs(np.min(DDD))) / abs(np.min(DDD)) * 255).astype('uint8')
img_DC = np.round((EEE+ abs(np.min(EEE))) / abs(np.min(EEE)) * 255).astype('uint8')
print("[Python] Debug Normalize")
# Normalize to [0, 255]
h, w = img_SubBgr.shape[:2]
img_SubBgr_norm = np.zeros((h, w)).astype('uint8')
print("[Python] Debug befor using cv2, version %s" % (cv2.__version__))
#<b>python hang in following function</b>
cv2.normalize(img_SubBgr, img_SubBgr_norm, 0, 255, cv2.NORM_MINMAX)
</li>
</ol>
The tree graph of these files is as below:
Project_Folder
|–transform_folder
| |–transform.cpp
| |–transform.h
| |–build_folder
|–algorithm_folder
|–processimage.py
I also did run the executing file for testing overnight yesterday.
But it still stuck in the line "cv2.normalize(img_SubBgr, img_SubBgr_norm, 0, 255, cv2.NORM_MINMAX)" when I was coming back to the office this morning.
Is there anything I missed?
I also tried to add "PyGILState_STATE mPyGILState = PyGILState_Ensure()" and "PyGILState_Release(mPyGILState)" in handleImageProcess(...).
But this is not work, either.
Regards,
C.T.")
+ QApplication::applicationDirPath()
+ QString("/../../transform_algorithm")
+ QString("
</li>
<li> transform.h
Q_OBJECT
public:
transform(…);
~transform();
private:
</li>
-- coding: utf-8 --
import numpy as np
import numpy.matlib
import os
import cv2
import time
import re
else:
</li>
</ol>
Project_Folder
|–transform_folder
| |–transform.cpp
| |–transform.h
| |–build_folder
|–algorithm_folder
|–processimage.py
Regards,
C.T.)");
qDebug() << "FuncPath: " << pyFuncPath;
PyRun_SimpleString("import sys");
PyRun_SimpleString("import numpy as np");
PyRun_SimpleString("import numpy.matlib");
PyRun_SimpleString("import matplotlib.pyplot as plt");
PyRun_SimpleString("import os");
PyRun_SimpleString("from array import array");
PyRun_SimpleString("import numpy.fft as fft");
PyRun_SimpleString("import cv2");
PyRun_SimpleString("import time");
PyRun_SimpleString("import re");
PyRun_SimpleString("from PIL import Image");
// Add current executed location into sys
PyRun_SimpleString("sys.path.append('./')");
PyRun_SimpleString(pyFuncPath.toLocal8Bit().data());
//Load python module
mPyModule = PyImport_ImportModule(PYTHON_MODULE_NAME);
if (!mPyModule) {
return ERROR_LOAD_MODULE_FAILED;
Py_INCREF(mPyModule);
// Get function list from python module
mPyFuncDict = PyModule_GetDict(mPyModule);
if (!mPyFuncDict) {
return ERROR_CANNOT_FIND_FUNC_DICTIONARY;
Py_INCREF(mPyFuncDict);
// Load function
mPyFunc = PyDict_GetItemString(mPyFuncDict, PYTHON_ALGORITHM_NAME);
if (!mPyFunc || !PyCallable_Check(mPyFunc)) {
return ERROR_LOAD_FUNCTION_FAILED;
Py_INCREF(mPyFunc);
return 0;
void transform::receiveImage(...) {
if (isProcess) {
qDebug() << "Buff " << buffIndex << ": " << "Start imageProcess";
QFuture<void> imageProcessFuture = QtConcurrent::run(this, &transform::handleImageProcess);
imageProcessWatcher->setFuture(imageProcessFuture);
void transform::handleImageProcess() {
if(imageProcessed) {
qDebug() << "ImageProcess: " << processFolderName;
PyObject *pyResult = nullptr;
// Necessary to convert QString to String while passing QString to Python
PyObject *pyArgs = PyTuple_New(1);
PyTuple_SetItem(pyArgs, 0, Py_BuildValue("s", processFolderName.toLocal8Bit().data()));
Py_INCREF(pyArgs);
pyResult = PyEval_CallObject(mPyFunc, pyArgs);
Py_INCREF(pyResult);
Py_DECREF(pyArgs);
if (pyResult)
Py_DECREF(pyResult);
