Hi, so after I looked up some threads and github discussion about how to grab frame from jetson inference, it turns out I need to convert it into numpy. What I’m trying to do is, to grab frame from jetson inference with the box detection included, like this thread Detectnet - object in frames - #3 by nerk , I need to convert captured camera to numpy
bgr_img = jetson.utils.cudaFromNumpy(cv_img, isBGR=True)
and also the sample from this thread is not enough so I look for another thread and it’s from Jetson Inference GitHub Issue, at the end of this github issue @dust-nv said to convert the camera captured to opencv, we need to add additional:
bgr_img = jetson.utils.cudaAllocMapped(width=rgb_img.width,height=rgb_img.height,format='bgr8')
and from those two threads, I ended up with this code
import numpy as np
import math
import jetson_inference
import jetson_utils
import cv2
from network import NetworkTable
# e = argparse.ArgumentParser
net = jetson_inference.detectNet(argv=['--model=models/roboflow.ai/ssd-mobilenet-4.onnx', '--labels=models/roboflow.ai/labels.txt', '--input-blob=input_0', '--output-cvg=scores', '--threshold=0.4', '--output-bbox=boxes'])
camera = jetson_utils.videoSource("v4l2:///dev/video0", ['--input-width=640', '--input-height=640'])
speed=0.0
if __name__ == '__main__':
bgr_img = None
cv_img = None
networkTable = NetworkTable()
# print("camera.IsStreaming()", camera.IsStreaming())
while True:
img = camera.Capture()
detections = net.Detect(img, width=img.width, height=img.height, overlay='none')
#cv_img = jetson.utils.cudaToNumpy(img)
if bgr_img is None:
bgr_img = jetson_utils.cudaAllocMapped(width=img.width, height=img.height, format="bgr8")
jetson_utils.cudaConvertColor(img, bgr_img)
cv_img = jetson_utils.cudaToNumpy(bgr_img)
jetson_utils.cudaDeviceSynchronize()
#get the object with the highest weight
currentFocusObj = None
angleSolver = AngleSolver()
classID = ""
for detection in detections:
x1 = detection.Left
x2 = detection.Right
y1 = detection.Top
y2 = detection.Bottom
print("x1: ", x1)
print("x2: ", x2)
print("y1: ", y1)
print("y2: ", y2)
# cv2.rectangle(cv_img, (x1, y1), (x2, y2), (0, 0, 255), 2)
classID = net.GetClassDesc(detection.ClassID)
object = Object([x1,y1,x2,y2], classID)
if object.compareWeight(currentFocusObj):
currentFocusObj = object
#info.OverlayText(cv_img, 5, 5,"speed:{:.2f}".format(speed),int(detection.Left)+5, int(detection.Top)+35, info.White, info.Gray40)
cv2.namedWindow("Output", cv2.WINDOW_NORMAL)
cv2.imshow("Output", cv_img)
#new_img = jetson_utils.cudaFromNumpy(cv_img, isBGR=True)
#display.Render(new_img)
#display.SetStatus("Object Detection | Network {:.0f} FPS".format(net.GetNetworkFPS()))
#print(f"Angle to obj: {}")
if currentFocusObj == None:
continue
angleToObject = angleSolver(currentFocusObj)
print(f"Angle to obj {angleToObject} \n ClassID {classID}")
vals = [angleToObject, currentFocusObj.classID]
networkTable.putData(angleToObject, classID)
cv2.destroyAllWindows()
When I run the code, it runs without any error, however the output window doesn’t give any thing, it just transparent window, I expect the window should be captured frame from camera
