I would like to use an OpenGL texture in CUDA as a texture. If I understood right, you can use PBO to access the opengl texture in CUDA (using a PBO and ReadPixels). However, this PBO is linear memory, and not a cudaArray. However, I would like to use texture filtering which requires the memory to be a cudaArray. The only way I can see is that I have to do a second copy from linear memory (registered PBO) to a cudaArray and bind it as texture in CUDA.
There’s a sample in CUDA SDK that demostrates OpenGL and CUDA interoperability with textures. Take a look at that as a starting point. You bind buffers to CUDA objects. There’s only one implied memcopy involved.
