OpenGL Interoperability (texture)
I would like to use texture I already have on cuda memory as opengl texture. I saw a few old examples which use pbo, but also one (real complex) that doesn’t (https://github.com/nvpro-samples/gl_cuda_interop_pingpong_st).
Is there a simple example that show how this can be done? Something like vbo has in the cuda programming guide (3.2.12.1. OpenGL Interoperability).
Furthermore, what is the recommended way to do this? Is it the pbo way or the “sharing” way (didn’t had a better word for it). It is really hard to tell with so much old material online.
my main thread:
void VideoRenderer::TheardProc()
	cuCtxSetCurrent(cuContext); //check
	cuMemAlloc(&p_texture, width * height * 4); //check
	cuMemsetD8(p_texture, 0, width * height * 4); //check
	cuCtxSynchronize();
	// Initialise GLFW
	if (!glfwInit())
		fprintf(stderr, "Failed to initialize GLFW\n");
		getchar();
		return;
	glfwWindowHint(GLFW_SAMPLES, 4);
	glfwWindowHint(GLFW_CONTEXT_VERSION_MAJOR, 3);
	glfwWindowHint(GLFW_CONTEXT_VERSION_MINOR, 3);
	glfwWindowHint(GLFW_OPENGL_FORWARD_COMPAT, GL_TRUE); // To make MacOS happy; should not be needed
	glfwWindowHint(GLFW_OPENGL_PROFILE, GLFW_OPENGL_CORE_PROFILE);
	// Open a window and create its OpenGL context
	window = glfwCreateWindow(1024, 768, "Tutorial 07 - Model Loading", NULL, NULL);
	if (window == NULL) {
		fprintf(stderr, "Failed to open GLFW window. If you have an Intel GPU, they are not 3.3 compatible. Try the 2.1 version of the tutorials.\n");
		getchar();
		glfwTerminate();
		return;
	glfwMakeContextCurrent(window);
	// Initialize GLEW
	glewExperimental = true; // Needed for core profile
	if (glewInit() != GLEW_OK) {
		fprintf(stderr, "Failed to initialize GLEW\n");
		getchar();
		glfwTerminate();
		return;
	//glEnable(GL_DEBUG_OUTPUT);
	//glDebugMessageCallback(MessageCallback, 0);
	// Ensure we can capture the escape key being pressed below
	glfwSetInputMode(window, GLFW_STICKY_KEYS, GL_TRUE);
	// Hide the mouse and enable unlimited mouvement
	glfwSetInputMode(window, GLFW_CURSOR, GLFW_CURSOR_DISABLED);
	// Set the mouse at the center of the screen
	glfwPollEvents();
	glfwSetCursorPos(window, 1024 / 2, 768 / 2);
	// Dark blue background
	glClearColor(0.0f, 0.0f, 0.4f, 0.0f);
	// Enable depth test
	glEnable(GL_DEPTH_TEST);
	// Accept fragment if it closer to the camera than the former one
	glDepthFunc(GL_LESS);
	// Cull triangles which normal is not towards the camera
	glDisable(GL_CULL_FACE);
	GLuint VertexArrayID;
	glGenVertexArrays(1, &VertexArrayID);
	glBindVertexArray(VertexArrayID);
	// Create and compile our GLSL program from the shaders
	GLuint programID = LoadShaders("TransformVertexShader.vertexshader", "TextureFragmentShader.fragmentshader");
	// Get a handle for our "MVP" uniform
	GLuint MatrixID = glGetUniformLocation(programID, "MVP");
	// Create one OpenGL texture
	GLuint Texture;
	glGenTextures(1, &Texture);
	// "Bind" the newly created texture : all future texture functions will modify this texture
	glBindTexture(GL_TEXTURE_2D, Texture);
	// set basic parameters
	glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_EDGE);
	glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_EDGE);
	glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
	glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
	glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA8UI_EXT, width, height, 0, GL_RGBA_INTEGER_EXT, GL_UNSIGNED_BYTE, NULL);
	CUgraphicsResource cuda_Tex;
	ck(cuGraphicsGLRegisterImage(&cuda_Tex, Texture, GL_TEXTURE_2D, CU_GRAPHICS_REGISTER_FLAGS_WRITE_DISCARD));
	ck(cuCtxSynchronize());
	// Get a handle for our "myTextureSampler" uniform
	GLuint TextureID = glGetUniformLocation(programID, "myTextureSampler");
	// Read our .obj file
	std::vector<glm::vec3> vertices;
	std::vector<glm::vec2> uvs;
	std::vector<glm::vec3> normals; // Won't be used at the moment.
	bool res = loadOBJ("cube.obj", vertices, uvs, normals);
	// Load it into a VBO
	GLuint vertexbuffer;
	glGenBuffers(1, &vertexbuffer);
	glBindBuffer(GL_ARRAY_BUFFER, vertexbuffer);
	glBufferData(GL_ARRAY_BUFFER, vertices.size() * sizeof(glm::vec3), &vertices[0], GL_STATIC_DRAW);
	GLuint uvbuffer;
	glGenBuffers(1, &uvbuffer);
	glBindBuffer(GL_ARRAY_BUFFER, uvbuffer);
	glBufferData(GL_ARRAY_BUFFER, uvs.size() * sizeof(glm::vec2), &uvs[0], GL_STATIC_DRAW);
	CUarray m_cudaArray;
	do {
		// Clear the screen
		glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
		// Use our shader
		glUseProgram(programID);
		// Compute the MVP matrix from keyboard and mouse input
		computeMatricesFromInputs();
		glm::mat4 ModelMatrix = glm::mat4(1.0);
		glm::mat4 MVP = ProjectionMatrix * ViewMatrix * ModelMatrix;
		// Send our transformation to the currently bound shader,
		// in the "MVP" uniform
		glUniformMatrix4fv(MatrixID, 1, GL_FALSE, &MVP[0][0]);
		ck(cuGraphicsMapResources(1, &cuda_Tex, 0));
		ck(cuGraphicsSubResourceGetMappedArray(&m_cudaArray, cuda_Tex, 0, 0)); // Bind the texture to its respective cuda array.
		CopyFrame(m_cudaArray);
		ck(cuGraphicsUnmapResources(1, &cuda_Tex, 0));
		// Bind our texture in Texture Unit 0
		glActiveTexture(GL_TEXTURE0);
		// Set our "myTextureSampler" sampler to use Texture Unit 0
		glUniform1i(TextureID, 0);
		// 1rst attribute buffer : vertices
		glEnableVertexAttribArray(0);
		glVertexAttribPointer(
			0,                  // attribute
			3,                  // size
			GL_FLOAT,           // type
			GL_FALSE,           // normalized?
			0,                  // stride
			(void*)0            // array buffer offset
		// 2nd attribute buffer : UVs
		glEnableVertexAttribArray(1);
			1,                                // attribute
			2,                                // size
			GL_FLOAT,                         // type
			0,                                // stride
		// Draw the triangle !
		glDrawArrays(GL_TRIANGLES, 0, vertices.size());
		glDisableVertexAttribArray(0);
		glDisableVertexAttribArray(1);
		// Swap buffers
		glfwSwapBuffers(window);
		glfwPollEvents();
	} // Check if the ESC key was pressed or the window was closed
	while (glfwGetKey(window, GLFW_KEY_ESCAPE) != GLFW_PRESS &&
		glfwWindowShouldClose(window) == 0 && (!bstop));
	// Free cuda memory
	cuMemFree(p_texture);
	// Cleanup VBO and shader
	glDeleteBuffers(1, &vertexbuffer);
	glDeleteBuffers(1, &uvbuffer);
	glDeleteProgram(programID);
	glDeleteTextures(1, &Texture);
	glDeleteVertexArrays(1, &VertexArrayID);
	// Close OpenGL window and terminate GLFW
	glfwTerminate();
	return;
void VideoRenderer::CopyFrame(CUarray &m_cudaArray)
	CUDA_MEMCPY2D m = { 0 };
	m.srcMemoryType = CU_MEMORYTYPE_DEVICE;
	m.srcDevice = p_texture;
	m.srcPitch = width * 4;
	m.dstMemoryType = CU_MEMORYTYPE_ARRAY;
	m.dstArray = m_cudaArray;
	m.dstPitch = width * 4;
	m.WidthInBytes = width * 4;
	m.Height = height;
	ck(cuMemcpy2DAsync(&m, 0)); //check
  • p_texture is being written from another thread.
Solved, I had a problem with the video format match.
