Hi all,
I am writing a dense vector field visualisation program in cuda. Basically I am implementing the noise advection and blending on the gpu using cuda, but then I want to be able to use the results as a texture with openGL.
my original solution worked but I know its not optimal,
display{
advect<<<512,256>>>(Nb_dev);
cudaMemcpy(Nb,Nb_dev,MTexNTex2*sizeof(float),
cudaMemcpyDeviceToHost);
glTexImage2D(GL_TEXTURE_2D,0,2,NTex,MTex,0,
GL_LUMINANCE_ALPHA,GL_FLOAT,Nb);
glBegin(GL_QUADS);
glTexCoord2f(0.0,0.0); glVertex2f(0,0);
glTexCoord2f(0.0,1.0); glVertex2f(MTex-1,0);
glTexCoord2f(1.0,1.0); glVertex2f(MTex-1,NTex-1);
glTexCoord2f(1.0,0.0); glVertex2f(0,NTex-1);
glEnd();
glutSwapBuffers();
now this works, but What I really want to do is avoid the memcpy from device to host (to me it seems silly to have to do this). After many hours of digging through the SDK examples I have attempted to use the open cuda/opengl interop functions in order to avoid this, my current attempt uses pixel buffer objects,
glGenBuffers(1,PBO);
glBindBuffer(GL_PIXEL_UNPACK_BUFFER,PBO);
glBufferData(GL_PIXEL_UNPACK_BUFFER,
NTexMTex2sizeof(GLfloat), NULL ,GL_DYNAMIC_DRAW);
glBindBuffer(GL_PIXEL_UNPACK_BUFFER, 0);
cudaGraphicsGLRegisterBuffer(&pbo_resource,*PBO,cudaGraphicsMapFlagsNone);
display{
float* tmp;
size_t num_bytes;
cudaGraphicsMapResources(1,&pbo_resource,0);
cudaGraphicsResourceGetMappedPointer((void**)&tmp,&num_bytes,pbo_resource);
advect<<<512,256>>>(tmp);
cudaGraphicsUnmapResources(1,&pbo_resource,0);
cudaThreadSynchronize();
glBindTexture(GL_TEXTURE_2D, tex[0]);
glBindBufferARB(GL_PIXEL_UNPACK_BUFFER_ARB,*PBO);
glTexImage2D(GL_TEXTURE_2D,0,2,NTex,MTex,0,GL_LUMINANCE_ALPH
A,GL_FLOAT,NULL);
glBindBufferARB(GL_PIXEL_UNPACK_BUFFER_ARB, 0);
glBindTexture(GL_TEXTURE_2D, 0);
glBegin(GL_QUADS);
glEnd();
glutSwapBuffers();
but all I get is a blank white texture… I know I am missing something, I also had a look at cudaGraphicsGLRegisterImages and the associated functions but to me it seemed like the textures here are always read only.
Anyway if anyone knows how to create a texture using cuda and texture map a quad with it in opengl without copying data to the host please show me how you did it, or if anyone knows if it cant be done.
Dave
