Dear,
Please find this modern Fortran program below with GPU offload using OpenMP
Using type bound procedure for my unk derived type generates a Segmentation fault (core dumped)
nvfortran --version
nvfortran 23.5-0 linuxarm64 target on aarch64 Linux -tp neoverse-n1
nvfortran -o exe -Minfo=mp -mp=gpu test.f90
If I break the type bound procedure and use classical SUBROUTINE with type(unk) as argument, it works
But I need to define map(to: sw, sw%h, sw%u ... and I don’t understand why sw is needed
If not, there is this error message:
Failing in Thread:1
Accelerator Fatal Error: call to cuMemcpyDtoHAsync returned error 700: Illegal address during kernel execution
Thanks very much for your answers :)
MODULE m_sw
USE iso_fortran_env, only: ip => INT32, rp => REAL64
implicit none
TYPE :: unk
real(rp), allocatable :: h(:)
real(rp), allocatable :: u(:)
real(rp), allocatable :: v(:)
CONTAINS
procedure, pass(sw) :: init => init_sw
procedure, pass(sw) :: run => run_sw
END TYPE unk
CONTAINS
SUBROUTINE init_sw(sw, n)
class(unk), intent(inout) :: sw
integer(ip), intent(in) :: n
allocate (sw%h(n), source=1._rp)
allocate (sw%u(n), source=0._rp)
allocate (sw%v(n), source=0._rp)
!$omp target enter data map(to: sw, sw%h, sw%u, sw%v)
END SUBROUTINE
SUBROUTINE run_sw(sw, n, nt)
integer(ip), intent(in) :: n , nt
integer(ip) :: ite , ic
do ite = 1,nt
!$omp target teams distribute parallel do
do ic = 2,n-1
sw%h(ic) = sw%h(ic) - ( sw%h(ic+1) * sw%u(ic+1) )
end do
end do
!$omp exit target data map(delete: sw, sw%h, sw%u, sw%v)
END SUBROUTINE
END MODULE m_sw
PROGRAM test
USE m_sw
implicit none
type(unk) :: sw
integer(ip), parameter :: n = 100
integer(ip), parameter :: nt = 1000
call sw%init( sw , n )
call sw%run( sw , n , nt )
END PROGRAM test
