I am trying to implement a code in which the cufft functions are called with device array allocated by openmp (address obtained from use_device_ptr). Something similar was done in the article belwo with openacc:
https://www.researchgate.net/publication/330940860_Three_Dimensional_Pseudo-Spectral_Compressible_Magnetohydrodynamic_GPU_Code_for_Astrophysical_Plasma_Simulation
My problem is solving iteratively an time-dependent partial differential equation in inverse space. At each time step a non-linear term is computed in real space, then there are two cufft calls, followed by an update in k-space and finally a cufft call to get the next step field.
My code works to compute the energy which means no change to the main field, but the update routine does not seem to work. The field appears to be unchanged after the iteration.
The idea is to have many stepswith the fields on the device and very rare transfer to the host. Is there something subtle happening with the device pointers? In the case of openacc+cufft they set the plan to the acc stream. COuld this be the issue? Is there equivalent way to get the stream for the openmp?
Cristian
MODULE F_T_C
INTERFACE
subroutine new_dpr2c(plan,idata,odata) bind(C,name="dpr2c_for_interface")
use iso_c_binding
implicit none
type(c_ptr), value :: plan
type(c_ptr),value :: idata,odata
end subroutine
subroutine new_dpc2r(plan,idata,odata) bind(C,name="dpc2r_for_interface")
use iso_c_binding
implicit none
end subroutine
subroutine new_make_plan_double_r2c(plan,nx,ny) bind(C,name="make_plan_double_r2c_for_interface")
use iso_c_binding
implicit none
type(c_ptr) :: plan
integer(c_int),value :: nx,ny
end subroutine
subroutine new_make_plan_double_c2r(plan,nx,ny) bind(C,name="make_plan_double_c2r_for_interface")
use iso_c_binding
implicit none
type(c_ptr) :: plan
end subroutine
END INTERFACE
END MODULE F_T_C
PROGRAM test
use iso_c_binding
use omp_lib
use F_T_C
implicit none
integer*4 :: ii,jj,cmm,it,id
integer(c_int), parameter :: lx=784, ly=512, lyhp=ly/2+1, nend=100
integer(c_int), parameter :: size_r=lx*ly, size_k=lx*(ly/2+1) ! Follow C order
real(c_double), parameter :: invvol=1.d0/(size_r) ! Follow C order
real(c_double), parameter :: pi=3.1415926535897931d0,sq3=1.7320508075688772d0
real(c_double), parameter :: qqt=sq3/2.d0
real(c_double), parameter :: at=2.d0*pi/qqt
real(c_double), parameter :: dt=0.125d0
real(c_double), parameter :: dx=at/8.d0,dy=(at*sq3/2.d0)/8.d0
real(c_double), parameter :: r=-0.25d0,pm=-0.25d0
real(c_double) :: rnd, ssuumm
!real(c_double):: psi_h(size_r), nt_h(size_r)
!complex(c_double_complex):: psi_k_h(size_k),nt_k_h(size_k)
real(c_double), Dimension(:), allocatable:: psi_h, nt_h, new_psi_h
complex(c_double_complex), Dimension(:), allocatable:: psi_k_h,nt_k_h, new_psi_k_h
type(c_ptr) :: planR2C, planC2R
real(c_double) :: dkx,dky
call init()
!$omp target enter data map(alloc:psi_h, new_psi_h, nt_h,psi_k_h,new_psi_k_h,nt_k_h)
!$omp target teams distribute parallel do private(cmm,ii,jj)
do ii=1, lx
do jj=1,ly
cmm=(ii-1)*ly+jj
psi_h(cmm)=-0.13*(dcos(qqt*(ii-1)*dx) *dcos(qqt*(jj-1)*dy/dsqrt(3.d0))+0.5*dcos(2.0*qqt*(jj-1)*dy/dsqrt(3.d0)))+pm
enddo
enddo
!$omp end target teams distribute parallel do
!$omp target update from (psi_h)
rnd=sum(psi_h)*invvol-pm
!psi_h=psi_h-rnd
write(*,*) rnd, dsqrt(3.d0), dacos(-1.d0), sum(psi_h)/(size_r)
!$omp target update to(psi_h) ! just in case
call energy()
do id=1, 1
do it=1,10 !nend
call update()
ssuumm=0.0
do ii=1, lx
do jj=1,ly
cmm=(ii-1)*ly+jj
ssuumm=ssuumm+abs(psi_h(cmm)-(-0.13*(dcos(qqt*(ii-1)*dx) *dcos(qqt*(jj-1)*dy/dsqrt(3.d0))+0.5*dcos(2.0*qqt*(jj-1)*dy/dsqrt(3.d0)))+pm))
enddo
enddo
print*, (ssuumm)*invvol
call energy()
enddo
stop
call energy()
write(*,*) id, sum(nt_h(1:size_r))*invvol, 0.5*(r+1.d0)*pm*pm+0.25*pm**4
enddo
!$omp target exit data
contains
subroutine update()
integer*4 :: ie, je
real(c_double) :: llfact, ntfact, fact,mksq,kkx,kky
integer*4 :: ccc
!Compute non-linear term
!$omp target teams distribute parallel do private(ccc,ie,je)
do ie=1, lx
do je=1,ly
ccc=(ie-1)*ly+je
nt_h(ccc)=psi_h(ccc)**3
enddo
enddo
!$omp target data use_device_ptr(psi_h,psi_k_h)
call new_dpr2c(planR2C, c_loc(psi_h),c_loc(psi_k_h))
!$omp end target data
!$omp target data use_device_ptr(nt_h,nt_k_h)
call new_dpr2c(planR2C, c_loc(nt_h),c_loc(nt_k_h))
!$omp target teams distribute parallel do private(ccc,ie,je,fact,llfact,ntfact,mksq,kkx,kky)
do ie=1, lx
if(ie<=lx/2+1) then
kkx=dkx*(ie-1.d0)
endif
if(ie>lx/2+1) then
kkx=dkx*(ie-1.d0-lx)
endif
do je=1,lyhp
ccc=(ie-1)*lyhp+je
kky=dky*(je-1.d0)
mksq=-(kkx*kkx+kky*kky)
llfact=(r+1.d0+2.d0*mksq+mksq*mksq)
fact=1.d0/(1.d0-dt*mksq*llfact)
ntfact=mksq*dt*1.d0/(1.d0-dt*mksq*llfact)
new_psi_k_h(ccc)=(psi_k_h(ccc)*fact+nt_k_h(ccc)*ntfact)*invvol
enddo
enddo
!$omp target data use_device_ptr(new_psi_h,new_psi_k_h)
call new_dpr2c(planC2R, c_loc(new_psi_k_h),c_loc(new_psi_h))
do ie=1, lx
do je=1,ly
ccc=(ie-1)*ly+je
nt_h(ccc)=new_psi_h(ccc)**3
enddo
enddo
call new_dpr2c(planR2C, c_loc(new_psi_h),c_loc(new_psi_k_h))
do ie=1, lx
if(ie<=lx/2+1) then
kkx=dkx*(ie-1.d0)
endif
if(ie>lx/2+1) then
endif
do je=1,lyhp
ccc=(ie-1)*lyhp+je
kky=dky*(je-1.d0)
psi_k_h(ccc)=(new_psi_k_h(ccc)*fact+nt_k_h(ccc)*ntfact)*invvol
enddo
enddo
call new_dpr2c(planC2R, c_loc(psi_k_h),c_loc(psi_h))
!!$omp target update from(psi_h)
!print *, sum(psi_h)*invvol
end subroutine
subroutine energy()
integer*4 :: ie, je
real(c_double) :: fact,mksq,kkx,kky
integer*4 :: ccc
!$omp target teams distribute parallel do private(ccc,ie,je,fact,mksq,kkx,kky)
do ie=1, lx
if(ie<=lx/2+1) then
kkx=dkx*(ie-1.d0)
endif
if(ie>lx/2+1) then
endif
do je=1,lyhp
ccc=(ie-1)*lyhp+je
kky=dky*(je-1.d0)
nt_k_h(ccc)=psi_k_h(ccc)*fact*invvol
enddo
enddo
call new_dpc2r(planC2R,c_loc(nt_k_h),c_loc(nt_h))
! Compute the local energy in real space
do ie=1, lx
do je=1,ly
ccc=(ie-1)*ly+je
nt_h(ccc)=0.5d0*psi_h(ccc) *nt_h(ccc)+0.25*(psi_h(ccc)**4)
enddo
enddo
!$omp target update from(nt_h)
!stop
end subroutine
subroutine init()
dkx=2.d0*pi/(lx*dx)
dky=2.d0*pi/(ly*dy)
call new_make_plan_double_r2c(planR2C, lx, ly)
call new_make_plan_double_c2r(planC2R, lx, ly)
allocate(psi_h(size_r),nt_h(size_r))
allocate(psi_k_h(size_k),nt_k_h(size_k))
allocate(new_psi_k_h(size_k),new_psi_h(size_r))
end subroutine
END PROGRAM test
