Opensuse 12.3 Nvidia CUDA 5.5 install issues
Hello Folks,
I’m having some issues with installing. Here are the steps I have taken.
I have installed the nvidia driver, seems to work perfectly. I downloaded cuda_5.5.22_linux_64.run and ran it.
I got it to install the toolkit in /usr/local/cuda/
I got it to put the samples in my home dir
I didn’t install the driver using this method, it doesn’t work plus compiled cuda apps work fine.
I have added /usr/local/cuda/bin to my /etc/bash.bashrc.local file and I can see the cuda compiler etc from the command line.
I have created /etc/ld.so.conf.d/cuda.conf file and in it I have put /usr/local/cuda/lib and lib64. I then ran ldconfig
I also tried just exporting the lib/lib64 dirs, just in case.
I also rebooted after doing all this.
gcc version is 4.7.2, I didn’t get any messages about it not being supported.
When I try to make the samples I get the error:
cc1plus: fatal error: cuda_runtime.h: No such file or directory.
I didn’t get any other errors during the install process. Any ideas why it can’t find the headers? I think I got all the steps.
Phil
Hi Phil,
Can you please check env “CUDA_PATH” in Makefile of your samples?
For example:
$ cd ~/NVIDIA_CUDA-5.5_Samples/NVIDIA_CUDA-5.5_Samples/1_Utilities/deviceQuery
$ grep “CUDA_PATH” Makefile
$ cd /usr/local/cuda/samples/1_Utilities/deviceQuery
The env “CUDA_PATH” should equal to CUDA installation path. And the header files are located in ${CUDA_PATH}/include.
The CUDA_PATH is /usr/local/cuda-5.5 which is correct, although I have a symlink from there too /usr/local/cuda I added /usr/local/cuda-5.5 to my path just in case it didn’t help.
I will try reinstalling, I just have to wait for a data analysis job to finish running…
Could you please run “make” under sample dir? It’s helpful to troubleshoot.
$ make
$ ls /usr/local/cuda-5.5/include
$ cd /usr/local/cuda-5.5/samples/1_Utilities/deviceQuery
$ sudo make
$ sudo make clean
This is a test post…
Right, I tried to post and it failed, very annoying… try again.
Sorry for being slow getting back to this. I was demonstrating science at the British Science Festival. :)
Ok, with the machine rebooted it still finds nvcc etc, and the /etc/ld.so.conf.d/cuda.conf has the path to /usr/local/cuda/lib64 and lib set. There is a symlink from /usr/local/cuda to /usr/local/cuda-5.5.
If I run make on deviceQuery I get the following error:
"/usr/local/cuda-5.5"/bin/nvcc -ccbin g++ -I../../common/inc  -m64    -gencode arch=compute_10,code=sm_10 -gencode arch=compute_20,code=sm_20 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=\"sm_35,compute_35\" -o deviceQuery.o -c deviceQuery.cpp
deviceQuery.cpp:20:18: fatal error: cuda.h: No such file or directory
compilation terminated.
make: *** [deviceQuery.o] Error 1
Same if I run “sudo make” after make clean etc.
The CUDA_PATH in the MakeFile is correct I checked with grep as suggested.
Any other suggestions?
I opened up Nsight and created a test project from the template. It couldn’t find cuda_runtime.h, so I added the path /usr/local/cuda/includes manually to the project. This suggests that the includes cannot be found generally.
Update on the above: If I import the DeviceQuery sample into Nsight and add the path to the includes to the project it can find cuda.h and cuda_runtime.h but I get the following error now.
ld: cannot find -lcudart_static
So there is still something wrong with the paths.
Did a total delete, download again and re-install. Got it! Its now working.
