Hi!
First I want to thank you again for always answering my questions.
I was using prime with a external monitor, but I bought a ssd and installed the last version of openSUSE Tumbleweed and… prime don’t works.
Laptop: Dell Inspiron 15 7000 gaming.
Kernel: 4.16.3-1-default
Video: Intel / Nvidia 1050 Ti (4GB)
# hwinfo --gfxcard
11: PCI 02.0: 0300 VGA compatible controller (VGA)
[Created at pci.378]
Unique ID: _Znp.y4PHO6GJ1i5
SysFS ID: /devices/pci0000:00/0000:00:02.0
SysFS BusID: 0000:00:02.0
Hardware Class: graphics card
Device Name: "Onboard IGD"
Model: "Intel VGA compatible controller"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x591b
SubVendor: pci 0x1028 "Dell"
SubDevice: pci 0x0798
Revision: 0x04
Driver: "i915"
Driver Modules: "i915"
Memory Range: 0xdd000000-0xddffffff (rw,non-prefetchable)
Memory Range: 0xb0000000-0xbfffffff (ro,non-prefetchable)
I/O Ports: 0xf000-0xf03f (rw)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
IRQ: 127 (193143 events)
Module Alias: "pci:v00008086d0000591Bsv00001028sd00000798bc03sc00i00"
Driver Info #0:
Driver Status: i915 is active
Driver Activation Cmd: "modprobe i915"
Config Status: cfg=new, avail=yes, need=no, active=unknown
25: PCI 100.0: 0300 VGA compatible controller (VGA)
Unique ID: VCu0.j8PTc__jCP3
Parent ID: vSkL.AoGxmxoz7cA
SysFS ID: /devices/pci0000:00/0000:00:01.0/0000:01:00.0
SysFS BusID: 0000:01:00.0
Model: "nVidia GP107M [GeForce GTX 1050 Ti Mobile]"
Vendor: pci 0x10de "nVidia Corporation"
Device: pci 0x1c8c "GP107M [GeForce GTX 1050 Ti Mobile]"
Revision: 0xa1
Driver: "nvidia"
Driver Modules: "nvidia"
Memory Range: 0xde000000-0xdeffffff (rw,non-prefetchable)
Memory Range: 0xc0000000-0xcfffffff (ro,non-prefetchable)
Memory Range: 0xd0000000-0xd1ffffff (ro,non-prefetchable)
I/O Ports: 0xe000-0xefff (rw)
Memory Range: 0xdf000000-0xdf07ffff (ro,non-prefetchable,disabled)
IRQ: 16 (no events)
Module Alias: "pci:v000010DEd00001C8Csv00001028sd00000798bc03sc00i00"
Driver Info #0:
Driver Status: nouveau is not active
Driver Activation Cmd: "modprobe nouveau"
Driver Info #1:
Driver Status: nvidia_drm is active
Driver Activation Cmd: "modprobe nvidia_drm"
Driver Info #2:
Driver Status: nvidia is active
Driver Activation Cmd: "modprobe nvidia"
Attached to: #20 (PCI bridge)
Primary display adapter: #11
# xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x46; cap: 0xb (Source Output, Sink Output, Sink Offload); crtcs: 4; outputs: 3; associated providers: 0; name: Intel
output eDP1
output DP1
output VIRTUAL1
I tried the steps in:
but the screen turns black and when I tried return to Intel (prime-select intel), the screen starts to flickering.
So I had to uninstall the nvidia driver and try again, but the result is the same.
Any help?
