I want to optimise code in the Yolo V3 https://github.com/ayooshkathuria/pytorch-yolo-v3/blob/master/darknet.py implementation in pytorch. Currently, its speed is 3fps.
Found this Pytorch Model to tensorrt converter code https://github.com/modricwang/Pytorch-Model-to-TensorRT/blob/master/main.py
import tensorrt
says
File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'tensorrt'
import pycuda
says
ModuleNotFoundError: No module named 'pycuda'
According to the SDK https://docs.nvidia.com/deeplearning/sdk/tensorrt-developer-guide/index.html,tensorrt is pre installed. I am confused.
Is this the correct way to use TensorRT?
New to this, would appreciate some guidance here
I found this Hello world example https://docs.nvidia.com/deeplearning/sdk/tensorrt-sample-support-guide/index.html#network_api_pytorch_mnist
Could find
/usr/src/tensorrt/samples/python/network_api_pytorch_mnist
trying to install requirements, i got his error
ERROR: torch-0.4.1-cp36-cp36m-linux_x86_64.whl is not a supported wheel on this platform.
