Hi everybody,
My OptiX 5.1.1-based application crashes on attempt to create optix buffer when I run it on A100-PCIE-40GB GPU. The minimal example that reproduces the problem looks as following:
#include <optix.h> #include <optixu/optixpp.h> int main() { optix::Context OptixContext = optix::Context::create(); optix::Buffer op_buf = OptixContext->createBuffer(RT_BUFFER_INPUT, RT_FORMAT_FLOAT); return 0; }
This program crashes on OptixContext->createBuffer(…) call with the following output:
pure virtual method called
terminate called without an active exception
The display driver version is 450.119.03, operating system is Ubuntu 20.04.
I tried building it with both cuda 10.1.243 and cuda 11, but the problem persists. I used g+±8 for building.
The error doesn’t pop up when I build and run the example above on older gpu, e.g., RTX 2080 with display driver 450.102.04.
Do Ampere series GPUs still support OptiX 5? If yes, then any ideas what might cause the problem and how to fix it?
Thanks in advance!
