I have download and build optix 6.5 SDK. Then i run the “optixDynamicGeometry” sample and change the default parameter “LayoutType” from SEPARATE_ACCELS to REBUILD_LAYOUT, it runs error.
The error is showed below.
Creating geometry ... OptiX Error: 'Invalid value (Details: Function "_rtGeometryInstanceGetGeometry" caught exception: Attached object is not a Geometry)'
The code triggers the error is:
Mesh mesh;
mesh.start_pos = mesh.last_pos = pos0;
mesh.end_pos = pos1;
mesh.move_start_time = 0.0;
<b>mesh.vertices = omesh.geom_instance->getGeometry()->queryVariable( "vertex_buffer" )->getBuffer();</b>
assert( mesh.vertices );
m_meshes.push_back( mesh );
My running environment is below:
OS: windows 10
GPU:GeForce 2080 ti
Driver version:441.08
IDE:VS 2019
