I’m getting this error on my project with optixModuleCreateFromPTX().
Same code before worked with 7.1.
I’ve also tested Optix7.2 on example 2 from the Optix7 course which uses optixModuleCreateFromPTX() and I get the same error…
That turned out to be a problem in these examples.
OptiX applications should meticulously default-initialize OptiX structures before setting the necessary parameters.
That is not the case in Ingo’s code.
/// Ingored if numBoundValues is set to 0
const OptixModuleCompileBoundValueEntry* boundValues;
/// set to 0 if unused
unsigned int numBoundValues;
Now if the OptixModuleCompileOptions have not been default-initialized when switching to the OptiX SDK 7.2.0 version, these two fields can contain random values and with a huge number of numBoundValues there will be a huge amount of memory allocated to manage them.
So either you get an OPTIX_ERROR_HOST_OUT_OF_MEMORY or an OPTIX_ERROR_UNKNOWN during optixModuleCreateFromPTX() if the boundValues is also random garbage.
These changes should fix it:
void SampleRenderer::createModule()
moduleCompileOptions = {}; // Was missing
moduleCompileOptions.maxRegisterCount = OPTIX_COMPILE_DEFAULT_MAX_REGISTER_COUNT; // Do not limit the amount of registers.
moduleCompileOptions.optLevel = OPTIX_COMPILE_OPTIMIZATION_DEFAULT; // or OPTIX_COMPILE_OPTIMIZATION_LEVEL_3;
moduleCompileOptions.debugLevel = OPTIX_COMPILE_DEBUG_LEVEL_NONE; // or OPTIX_COMPILE_DEBUG_LEVEL_LINEINFO;
pipelineCompileOptions = {};
pipelineCompileOptions.traversableGraphFlags = OPTIX_TRAVERSABLE_GRAPH_FLAG_ALLOW_SINGLE_GAS;
pipelineCompileOptions.usesMotionBlur = 0; // Type is int.
pipelineCompileOptions.numPayloadValues = 2;
pipelineCompileOptions.numAttributeValues = 2;
pipelineCompileOptions.exceptionFlags = OPTIX_EXCEPTION_FLAG_NONE;
pipelineCompileOptions.pipelineLaunchParamsVariableName = "optixLaunchParams";
pipelineLinkOptions = {}; // Was missing.
//pipelineLinkOptions.overrideUsesMotionBlur = 0; // Type is int. Removed in OptiX 7.1.0:
pipelineLinkOptions.maxTraceDepth = 2;
pipelineLinkOptions.debugLevel = OPTIX_COMPILE_DEBUG_LEVEL_NONE; // or OPTIX_COMPILE_DEBUG_LEVEL_LINEINFO; Should match with moduleCompileOptions.debugLevel // Was missing.
const std::string ptxCode = embedded_ptx_code;
char log[2048];
size_t sizeof_log = sizeof( log );
OPTIX_CHECK(optixModuleCreateFromPTX(optixContext,
&moduleCompileOptions,
&pipelineCompileOptions,
ptxCode.c_str(),
ptxCode.size(),
log,&sizeof_log,
&module
if (sizeof_log > 1)
PRINT(log);
