The question appears to be related to an error encountered while using the Jetson AGX Orin with JetPack 5.1.1 and VPI (Vision Programming Interface). The error message indicates that there is an issue with wrapping a buffer with a container, specifically a VPIImageData object.
After analyzing the provided context, I found several topics related to Jetson AGX Orin, JetPack, and VPI. However, none of them directly address the error message provided.
One possible cause of the error could be a mismatch between the buffer format and the container format. The VPIImageData object is used to represent image data, and the vpiImageSetWrapper function is used to set the wrapper for a VPIImage object. The error message suggests that the buffer cannot be wrapped by the container, which could indicate a format mismatch.
To troubleshoot this issue, I would recommend checking the following:
Verify that the buffer format matches the container format. Ensure that the buffer is in a format that can be wrapped by the VPIImageData container.
Check the documentation for vpiImageSetWrapper and VPIImageData to ensure that the correct parameters are being passed.
Review the VPI programming guide to ensure that the correct steps are being followed for creating and manipulating VPIImage objects.
If the issue persists, it may be helpful to provide more context or code snippets to further diagnose the problem.
In comparison to other topics in the provided context, this issue appears to be specific to the Jetson AGX Orin and VPI. Other topics related to Jetson AGX Orin, such as container runtime issues or PCIe problems, do not seem to be directly related to this error message.
