Hello, currently I’m developing using a torchvision network on the Orin, running my model within the docker image
Which is found here
The issue I’m currently facing is that I am able to successfully run data through torchvision networks, however the output is invalid/null/nan when running on the orin, however the output is valid when running on my x86_64 machine.
Here is example code that is able to reproduce this, keep in mind I have tested this across other models in the torchvision network as well, such as
#this keypoint model returns no keypoints when ran on the orin, where the same input data returns keypoints on an x86_64 machine
torchvision.models.detection.keypointrcnn_resnet50_fpn
Example code to reproduce the issue
import torchvision
import torchvision.transforms as transforms
# Load the pre-trained model
model = torchvision.models.resnet50(pretrained=True)
model.eval()
# Define the transform
transform = transforms.Compose([
transforms.Resize((224, 224)),
transforms.ToTensor(),
transforms.Normalize(mean=[0.485, 0.456, 0.406], std=[0.229, 0.224, 0.225])
# Load the CIFAR-10 dataset
dataset = torchvision.datasets.CIFAR10(root='./data', train=False, download=True, transform=transform)
# Use the first image from the dataset
image, label = dataset[23]
print("This is a picture of a ", label, "in CIFAR-10 labels. It is a fire truck")
# Add a batch dimension
image = image.unsqueeze(0)
# Run the image through the model
prediction = model(image).squeeze(0).softmax(0)
class_id = prediction.argmax().item()
score = prediction[class_id].item()
print(f"{class_id}: {100 * score:.1f}%")
print("This is a picture of a ", class_id, "in IMGNET labels. 555 is a firetruck...")
