我在适配GMSL驱动,使用的摄像头是SG3S-ISX031C-GMSL2F,驱动是GitHub - SENSING-Technology/nvidia-jetson-camera-drivers: Camera Drivers For NVIDIA Jetson Devices.
在官方开发板上面能正常运行,在我们自制载板不能运行
我看到是CSI接口的线序不一样,这是官方开发板的线序:
这是我们自制载板的线序:
请问是否可能通过修改设备树的方式来适配不一样的线序?
Suppose it’s HW limitation unable to configurate by SW.
Please check the design guide for the HW design.
@qiaowei
Please follow the design guide.
There’s no way to handle it by software for incorrect HW design.
In other words, DevKit uses the CSI1 interface, if I need to use the CSI0 interface, how to modify the software?
Do you connect to devkit? If not you may need to modify the port-index in device tree to verify.
Hi, I’m not using devkit
This is my device tree, I see a lot of port-index nodes, can you help me to see how to modify?
tegra234-camera-yuv-gmsl2x2-overlay.dts.txt (18.5 KB)
