Orin Nano 4G updates UEFI bin file
Orin Nano 4G updates UEFI bin file, JetPack 6.2 l4t_intrd_flash.sh after burning, UEFI version remains unchanged when booting up
Place the new version of the UEFI bin file in the bootloader directory and rename it uefi_jetson.bin. Use the l4t_intrd_flash. sh command to flash the file. After flashing, it was found that the compilation time in the UEFI log did not change
Hi 305248199,
Are you using the devkit or custom board for Orin Nano?
Please share the full command how do you flash the board.
I would also like to check the full flash log and serial console log during boot up.
@KevinFFF
custom board!
resolved
Pls tell how was the issue fixed. so that It will be helpful to others.
Also mark this post a Solution.
