Orin Nano module EEPROM dump
Hi, we are using the Orin Nano 8GB:
  • 699-level Part Number: 699-13767-0003-300 P.1
  • P-Number: p3767-0003
  • Module: NVIDIA Jetson Orin Nano (8GB ram)
  • Jetpack 6.0 [L4T 36.3.0]
The Jetson system have two EEPROMs, one on the module and one on the carrier board. Both EEPROMs are 256 bytes long, and they have similar formats.
We are using a custom carrier board and do not have an EEPROM on our carrier board so we would like to read the one in the Orin Nano module.
We would like to read the “Customer-overwritable section” outlined in Jetson EEPROM Layout
We have found two devices connected to on i2c buss 0 (address 0x50) and 4 (address 0x3C) and are unsure which one is the Orin modules EEPROM?
We have assumed that the EEPROM is the one on i2c buss 0 (address 0x50) but are unable to read the content:
fuser has verified that no process are using the device so we are unsure why the device is busy. Any help would be appreciated to read the 256 byte EEPROM
if you are using rel-36, run with sudo i2cdumo -f -y 0x50 and it will show the module eeprom info.
Hi Wayne, thanks for you help the -f worked:
sudo i2cdump -f -y 0 0x50
