Problem Summary:
We are running a dual IMX219 stereo camera setup on the Orin Nano Super. sensor-id=0 streams perfectly. sensor-id=1 always fails with:
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
NvBufSurfaceFromFd Failed
Argus successfully enumerates all 5 sensor modes for sensor-id=1 and reports “Producer has connected”, but fails immediately when trying to deliver the first frame.
Diagnostic Results:
Step 1 — Both cameras bind correctly in dmesg:
[3.458496] i2c-mux-gpio bus@0:cam_i2cmux: 2 port mux on 3180000.i2c adapter
[11.315953] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[11.332171] tegra-camrtc-capture-vi tegra-capture-vi: subdev imx219 9-0010 bound
[11.362147] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[11.380262] tegra-camrtc-capture-vi tegra-capture-vi: subdev imx219 10-0010 bound
No I2C errors, no error -121, no probe failures.
Step 2 — Root cause of original black screen was DTB overlay not applying:
The stock OVERLAYS directive in extlinux.conf is silently ignored on the Orin Nano Super. dmesg showed Overlayfs is disabled. We resolved this by manually merging the overlay into the base DTB using fdtoverlay:
bash
fdtoverlay -i kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb \
-o kernel_tegra234-p3768-0000+p3767-0005-nv-super-dual-cam.dtb \
tegra234-p3767-camera-p3768-imx219-dual.dtbo
After this, cam_i2cmux appeared correctly in the live device tree with both i2c@0 and i2c@1.
Step 3 — Device tree graph verified as correctly wired:
/proc/device-tree/tegra-capture-vi/ports/ → port@0 and port@1 both present
port@0 remote-endpoint = 0x376 (nvcsi channel@0 port@1 endpoint@1) ✅
port@1 remote-endpoint = 0x377 (nvcsi channel@1 port@1 endpoint@3) ✅
nvcsi channel@0 port@1 remote-endpoint = 0x379 (VI port@0 endpoint) ✅
nvcsi channel@1 port@1 remote-endpoint = 0x37b (VI port@1 endpoint) ✅
Full bidirectional graph is correctly linked.
Step 4 — vi-mapping confirmed:
nvidia,vi-mapping = <0x00 0x00 0x01 0x00 0x02 0x01 0x03 0x01 0x04 0x00 0x05 0x01>
CSI streams 2,3 map to vi-unit 1. We patched this to force all streams through vi0:
nvidia,vi-mapping = <0x00 0x00 0x01 0x00 0x02 0x00 0x03 0x00 0x04 0x00 0x05 0x00>
sensor-id=1 still fails with identical error after this change.
Step 5 — Tested in shared single Argus session:
bash
gst-launch-1.0 \
nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),...' ! fakesink \
nvarguscamerasrc sensor-id=1 ! 'video/x-raw(memory:NVMM),...' ! fakesink
sensor-id=0 streams for the full duration. sensor-id=1 still hits NvBufSurfaceFromFd Failed within 4 seconds.
Step 6 — Tried merging A+C single-camera overlays instead of dual overlay: Result: num-channels stayed at 1, overlays overwrote each other — not viable.
Step 7 — Upgraded to JetPack 36.4.7: Upgraded nvidia-l4t-kernel, nvidia-l4t-kernel-dtbs, nvidia-l4t-kernel-oot-modules, nvidia-l4t-gstreamer, nvidia-l4t-jetson-io. Rebuilt merged DTB with new base. Same error persists.
What we know for certain:
The problem is NOT ribbon cables (verified physically)
The problem is NOT I2C/driver binding (both cameras bind correctly)
The problem is NOT the device tree graph wiring (fully verified)
The problem is NOT vi1 DMA specifically (forcing vi0 doesn’t fix it)
The problem is NOT a session conflict (shared session tested)
Argus can open a CaptureSession for sensor-id=1 and enumerate modes — it fails only at frame buffer allocation
Question:
Is there a known issue with NvBufSurfaceFromFd failing for the second camera stream on the Orin Nano Super with dual IMX219? Is there a Super-specific camera DTB or BSP patch that correctly initializes the NVMAP/DMA buffer allocator for both VI pipelines simultaneously?
Any guidance appreciated. Happy to provide additional dmesg or device tree output on request.
