Hello, I am using the Orin NX module with L4T version R35.3.1 and have encountered some doubts.As shown in the following figure
I generated three files without making any name changes.
Orin-jetson_orin_nx_series_+hdmi a01-gpio-default.dtsi
Orin-jetson_orin_nx_series_+hdmi a01-padvoltage-default.dtsi
Orin-jetson_orin_nx_series_+hdmi a01-pinmux.dtsi
As described in the above figure, I need to copy the gpio- default.dtsi file to Linux_ For_ Tegra/bootloader directory; Copy padvoltage-default.dtsi and pinmux.dtsi to Linux_ For_ Tegra/bootloader/t186ref/BCT directory.
My question is:
- Copy the three files to these two directories separately, and the file names can be customized? Just add the defined file names again in the p3767.conf.common file? As follows
PINMUX_CONFIG=“Orin-jetson_orin_nx_series_+hdmi a01-pinmux.dtsi”
PMC_CONFIG=“Orin-jetson_orin_nx_series_+hdmi a01-padvoltage-default.dtsi”
- Only two files, pinmux.dtsi and padvoltage-default.dtsi, have been added to the “p3767.conf.common” file. Do we not need to add the “gpio-default.dtsi” file copied to the “Linux_for-Tegra/bootloader” directory? If not needed, why copy to the “Linux_for-Tegra/bootloader” directory?
