How to chang pinmux of Orin(t234)?
We’ve got the orin pinmux excel file from download center, and want to change CAN Bus pins configuration.
according to the Developer Guide Pinmux Changes
there is only “Linux_for_Tegra/kernel/pinmux/t19x”, buf not for t234. then use t19x for orin or where can i get the pinmux script for t234(orin)?
There is no such script because Orin’s pinmux setting is using dtsi file.
thanks for reply.
is there some docs or notes about change pinmux dtsi of Orin?
No document yet. But the pinmux dts is just under Linux_for_Tegra/bootloader.
Linux_for_Tegra/bootloader/tegra234-mb1-bct-pinmux-p3701-0000.dtsi
Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
which one should i modify?
The first one is actually the copy for the second one.
just like below diff file shows, they have many differences. so which one should i select to change?
pinmux.diff (4.9 KB)四
Oh ok. Then I don’t know either.
You can just flash the board once and see the log to tell which one is in use.
after flash.sh, the above file be recovered, from below file flash.log, can’t find out the map of the dtsi file.
please help to have a check, thanks.
flash.log (451.0 KB)
Why?
The first search result of “pinmux” directly gives this.
copying pinmux_config(/media/jaloo/4b30e570-5953-4e3f-bd28-3daec93ead76/jetpack_5.0/downloads/drivers/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3701-0000.dtsi)… done.
maybe that is copy result, but there isn’t copy source
Could you share what is under your t186ref/BCT/?
I can see that file under my jetpack folder.
bootloader_t186ref_BCT.txt (2.9 KB)
tegra234-mb1-bct-gpioint-p3701-0000.dts
tegra234-mb1-bct-misc-p3701-0000.dts
tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi
tegra234-mb1-bct-padvoltage-p3701-0000.dtsi
tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi.bak
tegra234-mb1-bct-pinmux-p3701-0000.dtsi -> ?????
tegra234-mb1-bct-pmic-p3701-0000.dts
tegra234-mb1-bct-prod-p3701-0000.dts
tegra234-mb1-bct-ratchet-p3701-0000.dts
tegra234-mb1-bct-reset-p3701-0000.dts
tegra234-mb1-bct-uphy-lanes-p3701-0000.dts
you mean the source file is
can be copied to
so i should modify the file
OK, thanks, i will try
