we found the fan turns very fast during bootLoader,we want to know how can we control the pwm-fan in the BootLoader,thanks
Hi lpz_thread,
Please note that FAN is enabled in MB2 but there’s no public source.
You could configure pwm-fan in UEFI through following definition.
https://github.com/NVIDIA/edk2-nvidia/blob/71fc2f6de48f3e9f01214b4e9464dd03620b876b/Silicon/NVIDIA/Drivers/TegraPwmDxe/TegraPwmDxe.c#L38
we use it on custom board with Linux R35.3.1
I don‘t know how can i configure the pwm in UEFI?where?
I’ve shared you the link with the specific line to modify the PWM_FAN_MED…
I means I could not find the PWM_FAN_MED in Linux R35.3.1,I don’t know how to Compiler /Silicon/NVIDIA/Drivers/TegraPwmDxe/TegraPwmDxe.c ,and put the result where
TegraPwmDxe.c
Why you could not find it…
It’s here: edk2-nvidia/Silicon/NVIDIA/Drivers/TegraPwmDxe/TegraPwmDxe.c at r35.3.1-updates · NVIDIA/edk2-nvidia (github.com)
Please refer to the wiki to clone and build the UEFI sources with r35.3.1-updates.
thanks ,if I modify the TegraPwmDxe.c in uefi,is it affect kernel pwm-fan?
No. They are independant.
thanks ,I have already modify the pwm-fan in MB2 ,but I found there’s still a lot of speed ahead before MB2,how can i modify the uefi soure code?
How did you modify in MB2?
Please just refer to above steps to modify in UEFI source.
Yes, I have already modify the pwm-fan in UEFI source.But it also have a short period of time that the pwm-fan output high
Before UEFI stage, there’s no custom modification available to configure pwm-fan.
ok,thanks
