Good evening, i’m trying to use the fan_pwm as a custom pwm, as i do not have any fan to use with my board.
I’m using a custom carrier board with an Nvidia AGX Orin, and i want to use the 32a0000.pwm, but when i try to access it using " echo 0 > export" i get an error saying that the resource is already busy.
Is there any way to free it? thanks in advance
Sorry for the late response.
Good morning,
i still need support, yes.
I tried to unlink writing to unexport with “echo 0 >unexport”, but i get an error saying that there is no such device.
When i tried the same technique with other pwms, it worked just fine, but for some reason with this one it doesn’t work.
I saw there is a Supplier-Consumer link between the 32a0000.pwm and the fan_pwm, and in each respective folder a “Consumer” and “Supplier” folder can be found, i suppose it links the two services?
I haven’t found a way to unlink them yet, maybe there’s some driver that allocates that resources and doesn’t let it go?
