Hi Sir,
L4T 32.6.1
Our custom carrier board(MP stage)
We want to control the PWM-FAN.
Ex: sudo echo 224 > /sys/devices/pwm-fan/target_pwm
[The current status]
nvidia@nvidia-desktop:/sys/devices/pwm-fan$ ls -la
total 0
drwxr-xr-x 3 root root 0 八 29 11:46 .
drwxr-xr-x 122 root root 0 八 29 11:46 …
-rw-r–r-- 1 root root 4096 八 29 11:46 driver_override
-r–r–r-- 1 root root 4096 八 29 11:46 modalias
lrwxrwxrwx 1 root root 0 八 29 11:46 of_node → …/…/firmware/devicetree/base/pwm-fan
drwxr-xr-x 2 root root 0 八 29 11:46 power
lrwxrwxrwx 1 root root 0 八 29 11:46 subsystem → …/…/bus/platform
-rw-r–r-- 1 root root 4096 八 29 11:46 uevent
[dmesg]
[ 2.071948] FAN dev name: pwm-fan
[ 2.071979] FAN:gpio request failed
[ 2.072091] pwm_fan_driver: probe of pwm-fan failed with error -22
I trace the driver source code and can not find out any key word.
[Device tree]
pwm-fan {
pwms = <&tegra_pwm6 0 45334>;
vdd-fan-supply = <&p3509_vdd_fan>;
profiles {
default = “quiet”;
quiet {
state_cap = <4>;
active_pwm = <0 130 160 200 255 255 255 255 255 255>;
cool {
state_cap = <4>;
active_pwm = <0 140 170 200 255 255 255 255 255 255>;
thermal-fan-est {
profiles {
default = “quiet”;
quiet {
active_trip_temps = <0 46000 60000 68000 76000
140000 150000 160000 170000 180000>;
active_hysteresis = <0 8000 8000 7000 7000
0 0 0 0 0>;
cool {
active_trip_temps = <0 35000 45000 53000 61000
0 0 0 0 0>;
We use the original source code and don’t change anything for FAN.
Can you teach us how to enable it?
(Our Nvidia Nano platform is OK.)
Thank you.
S.K.
Hi sk1977.huang,
It seems failed in the following snippet.
err = gpio_request(pwm_fan_gpio, "pwm-fan");
if (err < 0) {
pr_err("FAN:gpio request failed\n");
err = -EINVAL;
goto gpio_request_fail;
} else {
pr_info("FAN:gpio request success.\n");
Do you have the exact same fan design as the devkit?
Could you reproduce the same issue on the devkit or the issue is specific to your custom carrier board?
Hi Kevin,
I can get the snippet at the path ./kernenl_src/kernel/nvidia/drivers/thermal/pwm_fan.c.
It uses the gpio_request function.
From the topic:
Hello
I was investigating on how to change DTSI files to accomodate my backboard. I was searching for an example and I started from FAN PWM. As for the documentation and for the pinmux excel file, the FAN PWM must be connected on GPIO14, pin 230 of the Javier NX module p3668. From the excel file 1.06 I see that this GPIO is placed in H-1, so I tried to find it inside kernel sources. Searching inside the kernel distribution (I’m using JP 32.7.2) I can’t find any reference to it (only inside .h f…
/kernel_src/hardware/nvidia/platform/t19x/common/kernel-dts/t19x-common-platforms/tegra194-pwm-fan.dtsi:
pwm_fan_shared_data: pfsd {
num_resources = <0>;
secret = <47>;
active_steps = <10>;
active_rpm = <0 1000 2000 3000 4000 5000 6000 7000 10000 11000>;
rpm_diff_tolerance = <2>;
active_rru = <40 2 1 1 1 1 1 1 1 1>;
active_rrd = <40 2 1 1 1 1 1 1 1 1>;
state_cap_lookup = <2 2 2 2 3 3 3 4 4 4>;
pwm_period = <45334>;
pwm_id = <4>;
pwm_polarity = <PWM_POLARITY_INVERTED>;
suspend_state = <1>;
step_time = <100>; /* mesecs */
state_cap = <7>;
active_pwm_max = <256>;
tach_period = <1000>;
pwm_gpio = <&tegra_aon_gpio TEGRA194_AON_GPIO(CC, 4) GPIO_ACTIVE_LOW>;
pwm-fan {
compatible = "pwm-fan";
status = "okay";
#pwm-cells = <1>;
pwms = <&tegra_pwm4 0 45334>;
shared_data = <&pwm_fan_shared_data>;
profiles {
default = "quiet";
quiet {
state_cap = <4>;
active_pwm = <0 77 120 160 255 255 255 255 255 255>;
cool {
state_cap = <4>;
/kernel_src/hardware/nvidia/platform/t19x/jakku/kernel-dts/common/tegra194-p3509-0000-a00.dtsi:
pwm-fan {
profiles {
default = "quiet";
quiet {
state_cap = <4>;
cool {
state_cap = <4>;
thermal-fan-est {
profiles {
default = "quiet";
quiet {
0 0 0 0 0>;
cool {
0 0 0 0 0>;
Do I change tegra194-pwm-fan.dtsi ?
GPIO14 → (H,1)
[sk] Yes
[sk] The Image files cannot be shared between SOM and devkit.
I check the Nvidia Nano with our custom carrier board and Nano image.
I can see the control interface /sys/devices/pwm-fan/target_pwm .
S.K.
Hi Kevin,
We can use the control interface now.
Thank you so much!
S.K.
