• Hardware Platform (Jetson / GPU) - DGPU
• DeepStream Version 6.2
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 525.125.06
• Issue Type( questions, new requirements, bugs) Clarification
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) It can be reproduced in any Deepstream_test apps.
I am using back-to-back detector sample as my base application.
In that I need to change the bbox color based on PGIE and SGIE detection. I tried so many ways and there is no success. There are sample codes for previous versions of Deepstream and I cannot find for 6.2.
static GstPadProbeReturn
nvvidconv_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
NvDsObjectMeta *obj_meta = NULL;
guint vehicle_count = 0;
guint person_count = 0;
gfloat confidence = 0.0;
float border_width = 0.0;
guint64 Object_id_1 = 0;
guint64 Object_id_2 = 0;
char *Object_label = “Empty”;
guint face_count = 0;
guint lp_count = 0;
NvDsMetaList * l_frame = NULL;
NvDsMetaList * l_obj = NULL;
NvDsDisplayMeta *display_meta = NULL;
/*NvDsComp_BboxInfo *org_bbox_coords = NULL; */
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
int offset = 0;
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next) {
obj_meta = (NvDsObjectMeta *) (l_obj->data);
/* Check that the object has been detected by the primary detector
* and that the class id is that of vehicles/persons. */
if (obj_meta->unique_component_id == PRIMARY_DETECTOR_UID) {
if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE)
vehicle_count++;
confidence = obj_meta->confidence;
Object_id_1 = obj_meta->object_id;
if (obj_meta->class_id == PGIE_CLASS_ID_PERSON)
person_count++;
if (obj_meta->unique_component_id == SECONDARY_DETECTOR_UID) {
if (obj_meta->class_id == SGIE_CLASS_ID_FACE) {
face_count++;
/* Print this info only when operating in secondary model. */
if (SECOND_DETECTOR_IS_SECONDARY)
g_print ("Face found for parent object %p (type=%s)\n",
obj_meta->parent, pgie_classes_str[obj_meta->parent->class_id]);
if (obj_meta->class_id == SGIE_CLASS_ID_LP) {
lp_count++;
Object_id_2 = obj_meta->object_id;
Object_label = obj_meta->obj_label;
g_print ("License plate found for parent object %p (type=%s)\n",
display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
NvOSD_TextParams *txt_params = &display_meta->text_params[0];
NvOSD_RectParams *rect_params = &display_meta->rect_params[0];
display_meta->num_labels = 1;
txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Person = %d ", person_count);
offset += snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Vehicle = %d ", vehicle_count);
offset += snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Face = %d ", face_count);
offset += snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "License Plate = %d ", lp_count);
/* Now set the offsets where the string should appear */
txt_params->x_offset = 10;
txt_params->y_offset = 12;
/* Font , font-color and font-size */
txt_params->font_params.font_name = "Serif";
txt_params->font_params.font_size = 10;
txt_params->font_params.font_color.red = 1.0;
txt_params->font_params.font_color.green = 1.0;
txt_params->font_params.font_color.blue = 1.0;
txt_params->font_params.font_color.alpha = 1.0;
/* Text background color */
txt_params->set_bg_clr = 1;
txt_params->text_bg_clr.red = 0.0;
txt_params->text_bg_clr.green = 0.0;
txt_params->text_bg_clr.blue = 0.0;
txt_params->text_bg_clr.alpha = 1.0;
rect_params->border_color.red = 0.0;
rect_params->border_color.green = 0.0;
rect_params->border_color.blue = 1.0;
rect_params->border_color.alpha = 1.0;
rect_params->left = 10.0;
rect_params->top = 10.0;
rect_params->width = 450.0;
rect_params->height = 460.0;
rect_params->border_width = 5.0;
rect_params->has_bg_color = 1;
rect_params->bg_color.red = 0.0;
rect_params->bg_color.green = 0.0;
rect_params->bg_color.blue = 1.0;
rect_params->bg_color.alpha = 1.0;
border_width = display_meta->num_rects;
nvds_add_display_meta_to_frame(frame_meta, display_meta);
g_print ("Frame Number = %d Vehicle Count = %d Person Count = %d"
" Face Count = %d License Plate Count = %d Confidence = %f Object ID = %ld , %ld, Label = %s , Width = %f \n",
frame_number, vehicle_count, person_count,
face_count, lp_count, confidence, Object_id_1, Object_id_2, Object_label, border_width);
frame_number++;
return GST_PAD_PROBE_OK;
back_to_back_detectors.c (18.8 KB)
primary_detector_config.txt (2.8 KB)
secondary_detector_config.txt (3.1 KB)
tracker_config.txt (2.1 KB)
NVIDIA-SMI output:
Tue Jul 18 07:47:21 2023
| NVIDIA-SMI 525.125.06 Driver Version: 525.125.06 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA GeForce … On | 00000000:01:00.0 On | N/A |
| 0% 43C P8 12W / 285W | 448MiB / 12282MiB | 2% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1252 G /usr/lib/xorg/Xorg 35MiB |
| 0 N/A N/A 1811 G /usr/lib/xorg/Xorg 137MiB |
| 0 N/A N/A 1937 G /usr/bin/gnome-shell 29MiB |
| 0 N/A N/A 2298 G …mviewer/tv_bin/TeamViewer 3MiB |
| 0 N/A N/A 3751 G …RendererForSitePerProcess 45MiB |
| 0 N/A N/A 5563 G /usr/lib/firefox/firefox 183MiB |
Please help me to fix the issue.
Thank you.
