'osrt_sum' stats report no data available
I followed Unified Memory course.
I compile first example
nvcc -o single-thread-vector-add 01-vector-add/01-vector-add.cu -run
and
results are
Success! All values calculated correctly.
Generating '/tmp/nsys-report-eafc.qdstrm'
[1/8] [========================100%] report1.nsys-rep
[2/8] [========================100%] report1.sqlite
[3/8] Executing 'nvtx_sum' stats report
SKIPPED: /dli/task/report1.sqlite does not contain NV Tools Extension (NVTX) data.
[4/8] Executing 'osrt_sum' stats report
 Time (%)  Total Time (ns)  Num Calls   Avg (ns)    Med (ns)   Min (ns)  Max (ns)   StdDev (ns)           Name
     90.4       6154621709        318  19354156.3  10074556.0      2220  100141907   27631341.2  poll
      8.7        590645191        280   2109447.1   2066063.0       170   20541289    1278921.7  sem_timedwait
      0.6         43862349        499     87900.5     12780.0       380   10213399     606373.8  ioctl
      0.3         19354957         24    806456.5      5775.5      1080    7282794    2173280.8  mmap
      0.0          1141729         27     42286.3      4531.0      3030     785654     149169.7  mmap64
      0.0           511139         44     11616.8     10965.0      4510      34401       5260.6  open64
      0.0           200354         29      6908.8      4040.0      1470      55051      10010.5  fopen
      0.0           159332          4     39833.0     38960.5     27380      54031      13213.9  pthread_create
      0.0           131542         11     11958.4     12681.0      1010      16110       4573.5  write
      0.0           126084         12     10507.0      4960.0      1510      62562      16942.7  munmap
      0.0            58861         26      2263.9        90.0        70      56641      11090.8  fgets
      0.0            45330          6      7555.0      8395.0      3620       9840       2345.0  open
      0.0            38220         52       735.0       515.0       160       6160        847.7  fcntl
      0.0            32460         22      1475.5      1305.0       760       3340        697.1  fclose
      0.0            23200         14      1657.1      1375.0       520       4390       1219.8  read
      0.0            17580          2      8790.0      8790.0      5310      12270       4921.5  socket
      0.0            11700          5      2340.0       990.0        80       7170       2954.8  fread
      0.0            11490          1     11490.0     11490.0     11490      11490          0.0  connect
      0.0             6020          1      6020.0      6020.0      6020       6020          0.0  pipe2
      0.0             5550         64        86.7        50.0        40        170         45.7  pthread_mutex_trylock
      0.0             3390          1      3390.0      3390.0      3390       3390          0.0  bind
      0.0             1200          1      1200.0      1200.0      1200       1200          0.0  listen
      0.0              450          1       450.0       450.0       450        450          0.0  pthread_cond_broadcast
[5/8] Executing 'cuda_api_sum' stats report
     94.5       2471546863          1  2471546863.0  2471546863.0  2471546863  2471546863          0.0  cudaDeviceSynchronize
      4.8        124438386          3    41479462.0       58191.0       17761   124362434   71778762.1  cudaMallocManaged
      0.7         19455429          3     6485143.0     6167994.0     5964250     7323185     732880.4  cudaFree
      0.0            47231          1       47231.0       47231.0       47231       47231          0.0  cudaLaunchKernel
[6/8] Executing 'cuda_gpu_kern_sum' stats report
 Time (%)  Total Time (ns)  Instances    Avg (ns)      Med (ns)     Min (ns)    Max (ns)   StdDev (ns)                       Name
    100.0       2471537085          1  2471537085.0  2471537085.0  2471537085  2471537085          0.0  addVectorsInto(float *, float *, float *, int)
[7/8] Executing 'cuda_gpu_mem_time_sum' stats report
 Time (%)  Total Time (ns)  Count  Avg (ns)  Med (ns)  Min (ns)  Max (ns)  StdDev (ns)              Operation
     75.5         34140556   2304   14817.9    4351.5      1983     80192      22493.8  [CUDA Unified Memory memcpy HtoD]
     24.5         11060935    768   14402.3    3775.5      1279     80735      22787.8  [CUDA Unified Memory memcpy DtoH]
[8/8] Executing 'cuda_gpu_mem_size_sum' stats report
 Total (MB)  Count  Avg (MB)  Med (MB)  Min (MB)  Max (MB)  StdDev (MB)              Operation
    402.653   2304     0.175     0.033     0.004     1.044        0.301  [CUDA Unified Memory memcpy HtoD]
    134.218    768     0.175     0.033     0.004     1.044        0.301  [CUDA Unified Memory memcpy DtoH]
Generated:
    /dli/task/report1.nsys-rep
So no problem.
Now i run and compile same source code and use same command for nsys using windows 11 and cuda toolkit 12.5
nsys profile --stats=true .\single-thread-vector.exe
Generating 'C:\Users\UTILIS~1\AppData\Local\Temp\nsys-report-ecd2.qdstrm'
[1/8] [========================100%] report9.nsys-rep
[2/8] [========================100%] report9.sqlite
SKIPPED: C:\Users\laurent\Documents\Visual Studio 2022\cuda_course\report9.sqlite does not contain NV Tools Extension (NVTX) data.
SKIPPED: No data available.
     52,0        485592590          1  485592590,0  485592590,0  485592590  485592590          0,0  cudaDeviceSynchronize
     25,0        234802399          1  234802399,0  234802399,0  234802399  234802399          0,0  cudaLaunchKernel
     18,0        170693090          3   56897696,0   11941656,0   11541091  147210343   78213302,0  cudaMallocManaged
      3,0         33701527          3   11233842,0    5590101,0    5406366   22705060    9934790,0  cudaFree
      0,0            25365          1      25365,0      25365,0      25365      25365          0,0  cuLibraryUnload
      0,0             4323          1       4323,0       4323,0       4323       4323          0,0  cuModuleGetLoadingMode
      0,0             2846          1       2846,0       2846,0       2846       2846          0,0  cuCtxSynchronize
      0,0              262          1        262,0        262,0        262        262          0,0  cuDeviceGetLuid
    100,0        485544700          1  485544700,0  485544700,0  485544700  485544700          0,0  addVectorsInto(float *, float *, float *, int)
SKIPPED: C:\Users\laurent\Documents\Visual Studio 2022\cuda_course\report9.sqlite does not contain GPU memory data.
Generated:
    C:\Users\laurent\Documents\Visual Studio 2022\cuda_course\report9.nsys-rep
What’s wrong on windows with my command?
You might wish to ask this question on the nsight systems forum (e.g. the profiling windows targets sub-forum).
However, from here:
OS runtime trace is
not available for Windows targets.
I make a new post :
May be this one can be deleted
