Ota update Failer in jetpack 5.1.2
I’m using Jetson orin NX on jetson xavier Nx carrier board. I flash the carrier board using this command
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --showlogs --network usb0 p3509-a02+p3767-0000 external
I generated an ota image and tried to update.
ota generation command :
sudo -E ROOTFS_AB=1 TARGET_BSP=$WORKDIR/Linux_for_Tegra ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh --external-device nvme0n1 jetson-orin-nano-devkit R35-4
While trying to do the update it’s showing this error :
sudo ./nv_ota_start.sh /ota/ota_payload_package.tar.gz
Command: ./nv_ota_start.sh /ota/ota_payload_package.tar.gz
Current rootfs is on /dev/nvme0n1
init_ota_log /ota_log
Create log file at /ota_log/ota_20230315-154503.log
OTA_LOG_FILE=/ota_log/ota_20230315-154503.log
Extract /ota/ota_payload_package.tar.gz
update_nv_boot_control_in_rootfs /ota_work
Warning: Cannot get compatible board name.
3767-000-0000–1–p3509-a02+p3767-0000-
Info. Installing mtdblock.
Info. Active boot storage: nvme0n1
Info. Legacy mode: false
TNSPEC 3767-300-0000-K.1-1-1-p3509-a02+p3767-0000-
COMPATIBLE_SPEC 3767-000-0000–1–p3509-a02+p3767-0000-
TEGRA_LEGACY_UPDATE false
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Info: Write TegraPlatformCompatSpec with 3767-000-0000–1–p3509-a02+p3767-0000-.
Info. Uninstalling mtdblock.
check_prerequisites
decompress_ota_package ota_package.tar /ota_work
decompress_ota_package: start at Wed 15 Mar 2023 03:45:39 PM UTC
Sha1 checksum for /ota_work/ota_package.tar (c2fa7751f15dc57e3707aeb26902109192c1e00e) matches
decompress_ota_package: end at Wed 15 Mar 2023 03:45:57 PM UTC
nv_ota_update_without_layout_change.sh
Command: nv_ota_update_without_layout_change.sh
check_target_board /ota_work TARGET_BOARD
The board name in OTA package(jetson-orin-nano-devkit) does not match current board(p3509-a02+p3767-0000)
Failed to run “check_target_board /ota_work TARGET_BOARD”
In your flash command, you flashed the board without using ROOTFS_AB=1 and then set the OTA command with it, which is not supported.
Additionally, the board configuration jetson-orin-nano-devkit in your OTA command is incorrect. Please use p3509-a02+p3767-0000 instead. For example:
sudo -E TARGET_BSP=$WORKDIR/Linux_for_Tegra ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh --external-device nvme0n1 p3509-a02+p3767-0000 R35-4
@DavidDDD Tried the above command but couldn’t generate the OTA image
got error: Linux_for_Tegra/tools/ota_tools/version_upgrade/ota_validate_params.sh: line 75: P3509_A02+P3767_0000_R35_4_ALIAS: invalid variable name
One more question to confirm.
Is your Xavier NX a dev kit or the custom carrier board?
@DavidDDD Custom carrier board
In a custom carrier board, you should verify that it can be successfully flashed with the target BSP first.
@DavidDDD
I was able to successfully flash the target with this command :
@DavidDDD
What happens internally when we flash the board with different board name lets say in this case when I use p3509-a02+p3767-0000 and jetson-orin-nano-devkit
Have you successfully flashed JetPack 5.1.2 on your Orin NX
different board name catch different configure like device tree
