on my system. Apparently it is CUDA compatible. I downloaded the latest 2.1 version. Installed and compiled everything fine. But when I run the programs I am getting errors like this:
cudaSafeCall() Runtime API error in file <matrixMul.cu>, line 112 : out of memory.
Here are the diagnostics that might help,
tried different versions of the driver (180.22 and 180.44), neither worked.
tried g+±4.3 and g+±4.2, neither worked.
The only thing that seems to help is restarting the X server. All test programs seem to work fine for a while, but after running a few other programs, errors appear again.
My system has 2 GB of main memory and I have no other memory related problems.
I have already tried the Grub trick, /boot/grub/menu.lst :
This means you are out of graphics memory, not system memory. How much graphics memory does your GPU have? (deviceQuery in the SDK will show you this as well)
below is the output of the deviceQuery program’s output
./deviceQuery
There is 1 device supporting CUDA
Device 0: “GeForce 8400M GS”
Major revision number: 1
Minor revision number: 1
Total amount of global memory: 66387968 bytes
Number of multiprocessors: 2
Number of cores: 16
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 0.80 GHz
Concurrent copy and execution: Yes
Test PASSED
Press ENTER to exit…
i am not very sure what each field of the above output means, but i know the GeForce 8400M GS has 256MB of memory.
i doubt there is any reason for the device ram to be full under these conditions. do you have any ideas why the device memory would be filled and not freed during normal desktop usage?
This looks suspicious right here. The CUDA driver thinks you have a little less than 64 MB of device (“global”) memory. That’s definitely not enough to run any CUDA programs. Is this a separate card, or an integrated GPU on the motherboard that takes some of system memory for the GPU?
Hmm I was suspicious about that number : ) Thanks about the clarification.
If Sony is not tricking me here, it should be a separate card. This is a Sony VGN-SZ71MN laptop. I shall check the bios about that, but it did not see any menus offering graphics card memory settings.
I did check the bios right now, and there is no such option. I also checked the nvidia-settings utility and it seems to report 256MB ram, although this number could as well just be a table lookup from the device name.
I am thinking this might be a kernel related issue? Any ideas on that end?
It’s possible, but I’m out of ideas now. This is possibly some kind of kernel or driver problem, but the NVIDIA employees will have to comment.
It is worth noting that Ubuntu is a supported CUDA platform, but not Debian. You should check what kernel version Ubuntu 8.04 uses and maybe try that. It still might not work since each distro is known to add their own patches before the upstream kernel developers do.
Could give more information which specs are you looking at?
This model has two graphics devices, which you can switch between with a manual switch. One of the devices is the onboard intel device, which may have 64MB, but the other mode is supposed to have a 8400M GS working.
Are you saying this is not the case with the VRAM?
I found a similar laptop on the Sony site (slightly different model number, but I think it was a US versus Euro difference–it had the dual GPUs and very similar specs to what I had seen elsewhere), and it said that it had a lot of “shared video memory,” but only 64MB of dedicated video memory on the 8400M GS. So, there’s only 64MB available to CUDA.
I have no reason to think this is any sort of driver bug.
