Outputs of pytorch and tensorrt be accurately aligned
Description
In fact, I am currently working on a project to verify whether the outputs of pytorch and tensorrt can be accurately aligned.
I have tested both cases of conv and conv+bn, and the netron visualizations of the two models are shown in the following figure.
After testing, under model conv, the results of pytorch and tensorrt are completely consistent.
However, under model conv+bn, there is a difference of approximately 1e-6 in accuracy between the results of pytorch and tensorrt.
I suspect that Tensorrt did some optimization work, such as operator fusion. When building the Tensorrt engine, I added – builderOptimizationLevel=0, I think operator fusion may not be performed at this optimization level, but there is still a slight difference in accuracy between the final results of pytorch and tensorrt.
So, may I ask what is the internal reason for the difference in results, and is there any way to make this difference disappear
Environment
TensorRT Version: 8.6.1
GPU Type: GTX1060
Nvidia Driver Version: 545.29.06
CUDA Version: 12.1
CUDNN Version: 8.9.7
Operating System + Version: ubuntu20.04
Python Version (if applicable): python3.8
TensorFlow Version (if applicable): NO
PyTorch Version (if applicable): 2.1.2+cu121
Baremetal or Container (if container which image + tag): NO
Relevant Files
my onnx(from pytorch) and trt models are here:
test_model.zip (144.4 KB)
Steps To Reproduce
The following is a screenshot of the source code for torchvision.resnet. I added a return to end the inference earlier.
After entering a data for infer, you can also obtain that the result of “resnet50-part-conv” is the same, but there are differences in the result of “resnet50-part-cb”.
Hi @2087025789 ,
I am checking on this with Engineering team and shall update you soon.
