I am trying to run 8 * P106-100s in a CentOS 7.3 system. The drivers 384.47 and 384.59 only detect 7 GPUs.
My hardware detects and supports 8 GPUs.
[root@localhost ~]# lspci | grep NVIDIA
01:00.0 3D controller: NVIDIA Corporation Device 1c07 (rev a1)
02:00.0 3D controller: NVIDIA Corporation Device 1c07 (rev a1)
03:00.0 3D controller: NVIDIA Corporation Device 1c07 (rev a1)
05:00.0 3D controller: NVIDIA Corporation Device 1c07 (rev a1)
08:00.0 3D controller: NVIDIA Corporation Device 1c07 (rev a1)
09:00.0 3D controller: NVIDIA Corporation Device 1c07 (rev a1)
0a:00.0 3D controller: NVIDIA Corporation Device 1c07 (rev a1)
0b:00.0 3D controller: NVIDIA Corporation Device 1c07 (rev a1)
| NVIDIA-SMI 384.59 Driver Version: 384.59 |
| 0 P106-100 Off | 00000000:01:00.0 Off | N/A |
| 29% 35C P0 28W / 120W | 0MiB / 6075MiB | 0% Default |
| 1 P106-100 Off | 00000000:02:00.0 Off | N/A |
| 29% 39C P0 28W / 120W | 0MiB / 6075MiB | 0% Default |
| 2 P106-100 Off | 00000000:03:00.0 Off | N/A |
| 3 P106-100 Off | 00000000:05:00.0 Off | N/A |
| 4 P106-100 Off | 00000000:08:00.0 Off | N/A |
| 29% 40C P0 28W / 120W | 0MiB / 6075MiB | 0% Default |
| 5 P106-100 Off | 00000000:09:00.0 Off | N/A |
| 31% 41C P0 28W / 120W | 0MiB / 6075MiB | 0% Default |
| 6 P106-100 Off | 00000000:0B:00.0 Off | N/A |
| 29% 40C P0 28W / 120W | 0MiB / 6075MiB | 3% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
Additionally setting clock and memory speed is not supported for the P106-100. This is a severe limitation for GPUs purpose built for mining.
nvidia-smi -ac 1500,9000
Setting applications clocks is not supported for GPU 00000000:01:00.0.
Treating as warning and moving on.
Setting applications clocks is not supported for GPU 00000000:02:00.0.
Setting applications clocks is not supported for GPU 00000000:03:00.0.
Setting applications clocks is not supported for GPU 00000000:05:00.0.
Setting applications clocks is not supported for GPU 00000000:08:00.0.
Setting applications clocks is not supported for GPU 00000000:09:00.0.
Setting applications clocks is not supported for GPU 00000000:0B:00.0.
All done.
I purchased 496 of these GPUs and currently 1/8 are unusable. Additionally the other 7/8 are running 20% below desired and tested stable speeds in a test windows environment.
Please acknowledge and advise.
