I tried to install JetPack 5.0.1 DP on Xavier NX, along with Deepstream, but got this when updating:
The package system is broken
Check if you are using third party repositories. If so disable them, since they are a common source of problems.
Furthermore run the following command in a Terminal: apt-get install -f
Transaction failed: The package system is broken
The following packages have unmet dependencies:
cuda-libraries-dev-11-4: Depends: cuda-cudart-dev-11-4 (>= 11.4.243) but 11.4.243-1 is installed
Depends: cuda-cccl-11-4 (>= 11.4.222) but 11.4.222-1 is installed
Depends: cuda-profiler-api-11-4 (>= 11.4.239) but it is not installed
Depends: cuda-driver-dev-11-4 (>= 11.4.243) but 11.4.243-1 is installed
Depends: cuda-nvrtc-dev-11-4 (>= 11.4.239) but 11.4.239-1 is installed
Depends: libcublas-dev-11-4 (>= 11.6.6.23) but 11.6.6.23-1 is installed
Depends: libcudla-dev-11-4 (>= 11.4.239) but 11.4.239-1 is installed
Depends: libcusparse-dev-11-4 (>= 11.6.0.238) but 11.6.0.238-1 is installed
$ sudo apt install libcublas-11-4
Reading package lists⦠Done
Building dependency tree
Reading state information⦠Done
libcublas-11-4 is already the newest version (11.6.6.23-1).
libcublas-11-4 set to manually installed.
You might want to run āapt --fix-broken installā to correct these.
cuda-libraries-dev-11-4 : Depends: cuda-profiler-api-11-4 (>= 11.4.239) but it is not going to be installed
E: Unmet dependencies. Try āapt --fix-broken installā with no packages (or specify a solution).
I get similar messages for the other commands. If I try to fix the broken install, I get:
$ sudo apt --fix-broken install
Correcting dependencies⦠Done
The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin
cuda-nvprof-11-4 dctrl-tools dpkg-repack gir1.2-timezonemap-1.0
gir1.2-xkl-1.0 grub-common libdebian-installer4 libfwupdplugin1
libtimezonemap-data libtimezonemap1 os-prober python3-icu python3-pam rdate
tasksel tasksel-data
Use āsudo apt autoremoveā to remove them.
The following additional packages will be installed:
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 2 not upgraded.
8 not fully installed or removed.
Need to get 0 B/18.6 kB of archives.
After this operation, 90.1 kB of additional disk space will be used.
Do you want to continue? [Y/n]
debconf: delaying package configuration, since apt-utils is not installed
(Reading database ⦠154882 files and directories currently installed.)
Preparing to unpack ā¦/cuda-profiler-api-11-4_11.4.239-1_arm64.deb ā¦
Unpacking cuda-profiler-api-11-4 (11.4.239-1) ā¦
dpkg: error processing archive /var/cache/apt/archives/cuda-profiler-api-11-4_11
.4.239-1_arm64.deb (āunpack):
trying to overwrite ā/usr/local/cuda-11.4/targets/aarch64-linux/include/cudaPro
filer.hā, which is also in package cuda-nvprof-11-4 11.4.166-1
Errors were encountered while processing:
/var/cache/apt/archives/cuda-profiler-api-11-4_11.4.239-1_arm64.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
