Trying to create a docker image based on:
dustynv/ros:humble-ros-base-l4t-r35.1.0
When running apt-get update, getting the following error: #15 25.11 E: Failed to fetch https://repo.download.nvidia.com/jetson/common/dists/r35.1/main/binary-arm64/Packages.gz File has unexpected size (18667 != 19134). Mirror sync in progress? [IP: 82.102.152.163 443] #15 25.11 Hashes of expected file: #15 25.11 - Filesize:19134 [weak] #15 25.11 - SHA256:de4e5c93d1ad6ad832a33d40d1fcd5484f0d912ac2ee60cbba29489296a4fc0a #15 25.11 - SHA1:5e1dca51199a43fa5b4abb1a7ca2d4af6f6b65f6 [weak] #15 25.11 - MD5Sum:a09350bca3ceb5164749ad1a3467da10 [weak] #15 25.11 Release file created at: Tue, 30 Aug 2022 06:43:28 +0000 #15 25.11 E: Some index files failed to download. They have been ignored, or old ones used instead.
nvidia@tegra-ubuntu:~$ sudo apt-get update
[sudo] password for nvidia:
Hit:1 https://repo.download.nvidia.com/jetson/common r35.1 InRelease
Hit:2 https://repo.download.nvidia.com/jetson/t194 r35.1 InRelease
Hit:3 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Get:4 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease [114 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease [108 kB]
Get:6 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease [114 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 DEP-11 Metadata [278 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports focal-updates/universe arm64 DEP-11 Metadata [389 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports focal-backports/main arm64 DEP-11 Metadata [7968 B]
Get:10 http://ports.ubuntu.com/ubuntu-ports focal-backports/universe arm64 DEP-11 Metadata [30.5 kB]
Get:11 http://ports.ubuntu.com/ubuntu-ports focal-security/main arm64 DEP-11 Metadata [40.6 kB]
Get:12 http://ports.ubuntu.com/ubuntu-ports focal-security/universe arm64 DEP-11 Metadata [76.9 kB]
Fetched 1159 kB in 3s (343 kB/s)
Reading package lists... Done
nvidia@tegra-ubuntu:~$ cat /etc/apt/sources.list
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://ports.ubuntu.com/ubuntu-ports/ focal main restricted
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://ports.ubuntu.com/ubuntu-ports/ focal-updates main restricted
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://ports.ubuntu.com/ubuntu-ports/ focal universe
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal universe
deb http://ports.ubuntu.com/ubuntu-ports/ focal-updates universe
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://ports.ubuntu.com/ubuntu-ports/ focal multiverse
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal multiverse
deb http://ports.ubuntu.com/ubuntu-ports/ focal-updates multiverse
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://ports.ubuntu.com/ubuntu-ports/ focal-backports main restricted universe multiverse
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu focal partner
# deb-src http://archive.canonical.com/ubuntu focal partner
deb http://ports.ubuntu.com/ubuntu-ports/ focal-security main restricted
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal-security main restricted
deb http://ports.ubuntu.com/ubuntu-ports/ focal-security universe
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal-security universe
deb http://ports.ubuntu.com/ubuntu-ports/ focal-security multiverse
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal-security multiverse
MD5Sum:21b972e88f723e05f145ea802b9b0428 [weak]
Release file created at: Mon, 15 Aug 2022 18:31:52 +0000
Hit:4 Index of /ubuntu-ports focal InRelease
Hit:5 Index of /ubuntu-ports focal-updates InRelease
Hit:6 Index of /ubuntu-ports focal-backports InRelease
Hit:7 Index of /ubuntu-ports focal-security InRelease
Fetched 2,555 B in 1s (2,387 B/s)
Reading package lists… Done
E: Failed to fetch https://repo.download.nvidia.com/jetson/common/dists/r35.1/main/binary-arm64/Packages.gz File has unexpected size (19134 != 18667). Mirror sync in progress? [IP: 172.30.7.176 912]
- Filesize:18667 [weak]
- SHA256:7d90c4f673d6097a4641214c84dece042b4884cb47e0a74e8c1c2135e9859317
- SHA1:563b2b35beb8e1cd78e6219b2b91a1a3b7cf1006 [weak]
- MD5Sum:21b972e88f723e05f145ea802b9b0428 [weak]
