I put this script together from others in the internet. When I run one inference it runs at 10 fps 20% GPU. When I run 2 it runs at 5 fps 20% GPU. How can I make the GPU give more performance like in multiprocessing.?
import multiprocessing
import time
import cv2
import numpy as np
In screen FPS counter
timeStamp=time.time()
fpsFilt=0
code constants
th1=5
th2=100
frame_counter = 0
font=cv2.FONT_HERSHEY_SIMPLEX
reverse = 2560
whT = 320
confThreshold =0.5
nmsThreshold= 0.2
imgerror = cv2.imread(‘/home/kc/Downloads/darknet/C.jpg’)
def Cam1(to_AI1,): # 1 camera loop
fpsFilt=0
dispW=1280
dispH=720
cap5=cv2.VideoCapture('/dev/v4l/by-path/pci-0000:05:00.0-usb-0:2.3.3:1.0-video-index0')
cap5.set(cv2.CAP_PROP_FOURCC, cv2.VideoWriter_fourcc(*'MJPG'))
cap5.set(cv2.CAP_PROP_FRAME_WIDTH, dispW)
cap5.set(cv2.CAP_PROP_FRAME_HEIGHT, dispH)
while True:
success, img = cap5.read()
dt=time.time()-timeStamp
fps=1/dt
fpsFilt=.9*fpsFilt + .1*fps
cv2.putText(img,str(round(fpsFilt,1))+' fps cam',(0,70),font,1,(0,100,255),2)
if to_AI1.empty():
to_AI1.put(img)
if cv2.waitKey(1)==ord('q'):
break
cap5.release()
def Cam2(to_AI2,): # 1 camera loop
fpsFilt=0
dispW=1280
dispH=720
cap5=cv2.VideoCapture('/dev/v4l/by-path/pci-0000:05:00.0-usb-0:2.4:1.0-video-index0')
while True:
fps=1/dt
if to_AI2.empty():
to_AI2.put(img)
break
cap5.release()
def inference1_AI(to_AI1,): # inference from can1
global fpsFilt
global timeStamp
global frame_counter
classesFile = "/home/kc/Downloads/darknet/data/coco.names"
classNames = []
with open(classesFile, 'rt') as f:
classNames = f.read().rstrip('\n').split('\n')
print(classNames)
modelConfiguration = "/home/kc/Downloads/darknet/yolov4.cfg"
modelWeights = "/home/kc/Downloads/darknet/yolov4.weights"
net = cv2.dnn.readNetFromDarknet(modelConfiguration, modelWeights)
net.setPreferableBackend(cv2.dnn.DNN_BACKEND_OPENCV)
net.setPreferableTarget(cv2.dnn.DNN_TARGET_CPU)
while True:
if not to_AI1.empty():
img=to_AI1.get()
try:
while 1 not in img:
img = imgerror
except Exception:
img = imgerror
pass
else:
continue
blob = cv2.dnn.blobFromImage(img, 1 / 255, (whT, whT), [0, 0, 0], 1, crop=False)
net.setInput(blob)
layersNames = net.getLayerNames()
outputNames = [(layersNames[i - 1]) for i in net.getUnconnectedOutLayers()]
outputs = net.forward(outputNames)
hT, wT, cT = img.shape
bbox = []
classIds = []
confs = []
for output in outputs:
for det in output:
scores = det[5:]
classId = np.argmax(scores)
confidence = scores[classId]
if confidence > confThreshold:
w,h = int(det[2]*wT) , int(det[3]*hT)
x,y = int((det[0]*wT)-w/2) , int((det[1]*hT)-h/2)
bbox.append([x,y,w,h])
classIds.append(classId)
confs.append(float(confidence))
indices = cv2.dnn.NMSBoxes(bbox, confs, confThreshold, nmsThreshold)
for i in indices:
box = bbox[i]
x, y, w, h = box[0], box[1], box[2], box[3]
cv2.rectangle(img, (x, y), (x+w,y+h), (255, 0 , 255), 2)
cv2.putText(img,f'{classNames[classIds[i]].upper()} {int(confs[i]*100)}%',
(x, y-10), cv2.FONT_HERSHEY_SIMPLEX, 0.6, (255, 0, 255), 2)
fps=1/dt
cv2.putText(img,str(round(fpsFilt,1))+' fps AI',(0,30),font,1,(0,0,255),2)
cv2.imshow('inference1',img)
break
cv2.destroyAllWindows()
print('after brake')
def inference2_AI(to_AI2,): # inference from can1
global fpsFilt
global timeStamp
classNames = []
print(classNames)
while True:
if not to_AI2.empty():
img=to_AI2.get()
try:
while 1 not in img:
img = imgerror
except Exception:
img = imgerror
pass
else:
continue
net.setInput(blob)
bbox = []
classIds = []
confs = []
for det in output:
scores = det[5:]
for i in indices:
box = bbox[i]
fps=1/dt
cv2.imshow('inference2',img)
break
to_AI1 = multiprocessing.Queue()
to_AI2 = multiprocessing.Queue()
turret contol AI
t1Cam = multiprocessing.Process(target=Cam1, args=(to_AI1,))
t2Cam = multiprocessing.Process(target=Cam2, args=(to_AI2,))
turret contol AI
t1AI = multiprocessing.Process(target=inference1_AI, args=(to_AI1,))
t2AI = multiprocessing.Process(target=inference2_AI, args=(to_AI2,))
t1Cam.start() # cam start
time.sleep(.3)
t2Cam.start() # cam start
time.sleep(.3)
t1AI.start() # AI start
t2AI.start() # AI start
