Running Multiple TensorRT Engines On Jetson AGX
Hi, I created two TensorRT Engine files using this repo for YOLOv5s and YOLOv5m. The TensorRTs are running individually but I cannot run them at the same time.
this is YOLOv5 TRT format inferience script (for YOLOv5m and and YOLOv5s, they are same)
An example that uses TensorRT's Python api to make inferences.
import ctypes
import os
import shutil
import random
import sys
import threading
import time
import cv2
import numpy as np
import pycuda.autoinit
import pycuda.driver as cuda
import tensorrt as trt
import torch
import torchvision
CONF_THRESH = 0.2
IOU_THRESHOLD = 0.4
def plot_one_box(x, img, color=None, label=None, line_thickness=None):
    description: Plots one bounding box on image img,
                 this function comes from YoLov5 project.
    param:
        x:      a box likes [x1,y1,x2,y2]
        img:    a opencv image object
        color:  color to draw rectangle, such as (0,255,0)
        label:  str
        line_thickness: int
    return:
        no return
    tl = (
        line_thickness or round(0.002 * (img.shape[0] + img.shape[1]) / 2) + 1
    )  # line/font thickness
    color = color or [random.randint(0, 255) for _ in range(3)]
    c1, c2 = (int(x[0]), int(x[1])), (int(x[2]), int(x[3]))
    cv2.rectangle(img, c1, c2, color, thickness=tl, lineType=cv2.LINE_AA)
    if label:
        tf = max(tl - 1, 1)  # font thickness
        t_size = cv2.getTextSize(label, 0, fontScale=tl / 3, thickness=tf)[0]
        c2 = c1[0] + t_size[0], c1[1] - t_size[1] - 3
        cv2.rectangle(img, c1, c2, color, -1, cv2.LINE_AA)  # filled
        cv2.putText(
            img,
            label,
            (c1[0], c1[1] - 2),
            0,
            tl / 3,
            [225, 255, 255],
            thickness=tf,
            lineType=cv2.LINE_AA,
class YoLov5TRT(object):
    description: A YOLOv5 class that warps TensorRT ops, preprocess and postprocess ops.
    global categories
    # load custom plugins
    PLUGIN_LIBRARY = "yolov5mTRT/libmyplugins.so"
    engine_file_path = "yolov5mTRT/yolov5.engine"
    if len(sys.argv) > 1:
        engine_file_path = sys.argv[1]
    if len(sys.argv) > 2:
        PLUGIN_LIBRARY = sys.argv[2]
    ctypes.CDLL(PLUGIN_LIBRARY)
    categories = ["person", "bicycle", "car", "motorcycle", "airplane", "bus", "train", "truck", "boat", "traffic light",
            "fire hydrant", "stop sign", "parking meter", "bench", "bird", "cat", "dog", "horse", "sheep", "cow",
            "elephant", "bear", "zebra", "giraffe", "backpack", "umbrella", "handbag", "tie", "suitcase", "frisbee",
            "skis", "snowboard", "sports ball", "kite", "baseball bat", "baseball glove", "skateboard", "surfboard",
            "tennis racket", "bottle", "wine glass", "cup", "fork", "knife", "spoon", "bowl", "banana", "apple",
            "sandwich", "orange", "broccoli", "carrot", "hot dog", "pizza", "donut", "cake", "chair", "couch",
            "potted plant", "bed", "dining table", "toilet", "tv", "laptop", "mouse", "remote", "keyboard", "cell phone",
            "microwave", "oven", "toaster", "sink", "refrigerator", "book", "clock", "vase", "scissors", "teddy bear",
            "hair drier", "toothbrush"]
    if os.path.exists('output/'):
        shutil.rmtree('output/')
    os.makedirs('output/')
    # a YoLov5TRT instance
    def __init__(self, engine_file_path = engine_file_path):
        # Create a Context on this device,
        self.ctx = cuda.Device(0).make_context()
        stream = cuda.Stream()
        TRT_LOGGER = trt.Logger(trt.Logger.INFO)
        runtime = trt.Runtime(TRT_LOGGER)
        # Deserialize the engine from file
        with open(engine_file_path, "rb") as f:
            engine = runtime.deserialize_cuda_engine(f.read())
        context = engine.create_execution_context()
        host_inputs = []
        cuda_inputs = []
        host_outputs = []
        cuda_outputs = []
        bindings = []
        for binding in engine:
            print('bingding:', binding, engine.get_binding_shape(binding))
            size = trt.volume(engine.get_binding_shape(binding)) * engine.max_batch_size
            dtype = trt.nptype(engine.get_binding_dtype(binding))
            # Allocate host and device buffers
            host_mem = cuda.pagelocked_empty(size, dtype)
            cuda_mem = cuda.mem_alloc(host_mem.nbytes)
            # Append the device buffer to device bindings.
            bindings.append(int(cuda_mem))
            # Append to the appropriate list.
            if engine.binding_is_input(binding):
                self.input_w = engine.get_binding_shape(binding)[-1]
                self.input_h = engine.get_binding_shape(binding)[-2]
                host_inputs.append(host_mem)
                cuda_inputs.append(cuda_mem)
            else:
                host_outputs.append(host_mem)
                cuda_outputs.append(cuda_mem)
        # Store
        self.stream = stream
        self.context = context
        self.engine = engine
        self.host_inputs = host_inputs
        self.cuda_inputs = cuda_inputs
        self.host_outputs = host_outputs
        self.cuda_outputs = cuda_outputs
        self.bindings = bindings
        self.batch_size = engine.max_batch_size
    def infer(self, raw_image_generator):
        threading.Thread.__init__(self)
        # Make self the active context, pushing it on top of the context stack.
        self.ctx.push()
        # Restore
        stream = self.stream
        context = self.context
        engine = self.engine
        host_inputs = self.host_inputs
        cuda_inputs = self.cuda_inputs
        host_outputs = self.host_outputs
        cuda_outputs = self.cuda_outputs
        bindings = self.bindings
        # Do image preprocess
        batch_image_raw = []
        batch_origin_h = []
        batch_origin_w = []
        batch_input_image = np.empty(shape=[self.batch_size, 3, self.input_h, self.input_w])
        input_image, image_raw, origin_h, origin_w = self.preprocess_image(raw_image_generator)
        batch_image_raw.append(image_raw)
        batch_origin_h.append(origin_h)
        batch_origin_w.append(origin_w)
        np.copyto(batch_input_image[0], input_image)
        batch_input_image = np.ascontiguousarray(batch_input_image)
        # Copy input image to host buffer
        np.copyto(host_inputs[0], batch_input_image.ravel())
        start = time.time()
        # print(type(host_inputs))
        # Transfer input data  to the GPU.
        cuda.memcpy_htod_async(cuda_inputs[0], host_inputs[0], stream)
        # Run inference.
        context.execute_async(batch_size=self.batch_size, bindings=bindings, stream_handle=stream.handle)
        # Transfer predictions back from the GPU.
        cuda.memcpy_dtoh_async(host_outputs[0], cuda_outputs[0], stream)
        # Synchronize the stream
        stream.synchronize()
        end = time.time()
        # Remove any context from the top of the context stack, deactivating it.
        self.ctx.pop()
        # Here we use the first row of output in that batch_size = 1
        output = host_outputs[0]
        # Do postprocess
        objects = []
        for i in range(self.batch_size):
            result_boxes, result_scores, result_classid = self.post_process(
                output[i * 6001: (i + 1) * 6001], batch_origin_h[i], batch_origin_w[i]
            # Draw rectangles and labels on the original image
            for j in range(len(result_boxes)):
                box = result_boxes[j]
                plot_one_box(
                    box,
                    batch_image_raw[i],
                    label="{}:{:.2f}".format(categories[int(result_classid[j])], result_scores[j]),)
                objects.append(categories[int(result_classid[j])])
                # if categories[int(result_classid[j])] == "stack":
                #     x = box
                #     x1,y1,x2,y2 = int(x[0]), int(x[1]), int(x[2]), int(x[3])
                #     item = []
                #     item.append(categories[int(result_classid[j])])
                #     item.append(float(result_scores[j]))
                #     x = int((x2+x1)/2)
                #     y = int((y1+y2)/2)
                #     w = x2-x1
                #     h = y2-y1
                #     item.append([x,y,w,h])
                #     objects.append(item)
        return objects, end - start
        # return objects
    def destroy(self):
        self.ctx.pop()
    def get_raw_image_zeros(self, image_path_batch=None):
        description: Ready data for warmup
        for _ in range(self.batch_size):
            yield np.zeros([self.input_h, self.input_w, 3], dtype=np.uint8)
    def preprocess_image(self, raw_bgr_image):
        description: Convert BGR image to RGB,
                     resize and pad it to target size, normalize to [0,1],
                     transform to NCHW format.
        param:
            input_image_path: str, image path
        return:
            image:  the processed image
            image_raw: the original image
            h: original height
            w: original width
        image_raw = raw_bgr_image
        h, w, c = image_raw.shape
        image = cv2.cvtColor(image_raw, cv2.COLOR_BGR2RGB)
        # Calculate widht and height and paddings
        r_w = self.input_w / w
        r_h = self.input_h / h
        if r_h > r_w:
            tw = self.input_w
            th = int(r_w * h)
            tx1 = tx2 = 0
            ty1 = int((self.input_h - th) / 2)
            ty2 = self.input_h - th - ty1
        else:
            tw = int(r_h * w)
            th = self.input_h
            tx1 = int((self.input_w - tw) / 2)
            tx2 = self.input_w - tw - tx1
            ty1 = ty2 = 0
        # Resize the image with long side while maintaining ratio
        image = cv2.resize(image, (tw, th))
        # Pad the short side with (128,128,128)
        image = cv2.copyMakeBorder(
            image, ty1, ty2, tx1, tx2, cv2.BORDER_CONSTANT, (128, 128, 128)
        image = image.astype(np.float32)
        # Normalize to [0,1]
        image /= 255.0
        # HWC to CHW format:
        image = np.transpose(image, [2, 0, 1])
        # CHW to NCHW format
        image = np.expand_dims(image, axis=0)
        # Convert the image to row-major order, also known as "C order":
        image = np.ascontiguousarray(image)
        return image, image_raw, h, w
    def xywh2xyxy(self, origin_h, origin_w, x):
        description:    Convert nx4 boxes from [x, y, w, h] to [x1, y1, x2, y2] where xy1=top-left, xy2=bottom-right
        param:
            origin_h:   height of original image
            origin_w:   width of original image
            x:          A boxes tensor, each row is a box [center_x, center_y, w, h]
        return:
            y:          A boxes tensor, each row is a box [x1, y1, x2, y2]
        y = torch.zeros_like(x) if isinstance(x, torch.Tensor) else np.zeros_like(x)
        r_w = self.input_w / origin_w
        r_h = self.input_h / origin_h
        if r_h > r_w:
            y[:, 0] = x[:, 0] - x[:, 2] / 2
            y[:, 2] = x[:, 0] + x[:, 2] / 2
            y[:, 1] = x[:, 1] - x[:, 3] / 2 - (self.input_h - r_w * origin_h) / 2
            y[:, 3] = x[:, 1] + x[:, 3] / 2 - (self.input_h - r_w * origin_h) / 2
            y /= r_w
        else:
            y[:, 0] = x[:, 0] - x[:, 2] / 2 - (self.input_w - r_h * origin_w) / 2
            y[:, 2] = x[:, 0] + x[:, 2] / 2 - (self.input_w - r_h * origin_w) / 2
            y /= r_h
        return y
    def post_process(self, output, origin_h, origin_w):
        description: postprocess the prediction
        param:
            output:     A tensor likes [num_boxes,cx,cy,w,h,conf,cls_id, cx,cy,w,h,conf,cls_id, ...]
        return:
            result_boxes: finally boxes, a boxes tensor, each row is a box [x1, y1, x2, y2]
            result_scores: finally scores, a tensor, each element is the score correspoing to box
            result_classid: finally classid, a tensor, each element is the classid correspoing to box
        # Get the num of boxes detected
        num = int(output[0])
        # Reshape to a two dimentional ndarray
        pred = np.reshape(output[1:], (-1, 6))[:num, :]
        # to a torch Tensor
        pred = torch.Tensor(pred).cuda()
        # Get the boxes
        boxes = pred[:, :4]
        # Get the scores
        scores = pred[:, 4]
        # Get the classid
        classid = pred[:, 5]
        # Choose those boxes that score > CONF_THRESH
        si = scores > CONF_THRESH
        boxes = boxes[si, :]
        scores = scores[si]
        classid = classid[si]
        # Trandform bbox from [center_x, center_y, w, h] to [x1, y1, x2, y2]
        boxes = self.xywh2xyxy(origin_h, origin_w, boxes)
        # Do nms
        indices = torchvision.ops.nms(boxes, scores, iou_threshold=IOU_THRESHOLD).cpu()
        result_boxes = boxes[indices, :].cpu()
        result_scores = scores[indices].cpu()
        result_classid = classid[indices].cpu()
        return result_boxes, result_scores, result_classid
if __name__ == "__main__":
    yolov5_wrapper = YoLov5TRT()
    cam = cv2.VideoCapture('rtsp://*******')
    while True:
        ###get raw
        ret, frame = cam.read()
        if ret:
            print(yolov5_wrapper.infer(frame))
            # batch_image_raw, use_time = yolov5_wrapper.infer(frame) ### predict kısmı
            # fps = int(1/float(use_time))
            # # cv2.imwrite("output/save_name.jpg", batch_image_raw[0])
            # cv2.imshow("frame", batch_image_raw[0])
            # cv2.waitKey(1)
            # print(fps)
        else:
            print("Failed")
and this code for multi processing
from yolov5mTRT import YoLov5TRT as yolov5m
from yolov5sTRT import YoLov5TRT as yolov5s
import cv2
import multiprocessing
class yoloSthread(multiprocessing.Process):
    def run(self):
        print("yoloSSSSS started")
        while True:
            try:
                print("yoloSSSSS working")
                self.trt.infer(newFrame1)
            except:
                print("SSSSS error")
class yoloMthread(multiprocessing.Process):
    def run(self):
        global newFrame
        print("yoloMMMMMM started")
        while True:
            try:
                self.trt.infer(newFrame)
            except:
                print("MMMMM error")
class grabThread(multiprocessing.Process):
    def run(self):
            global newFrame
            global newFrame1
            grab, frame = self.cap.read()
            if grab:
                newFrame = frame
                newFrame1 = frame
                cv2.imshow("frame", newFrame)
            else:
                cap = cv2.VideoCapture(self.addr)
addr = 'rtsp://*******'
cap = cv2.VideoCapture(addr)
threads = []
jobs = []
f = grabThread()
jobs.append(f)
f.start()
m = yoloMthread()
jobs.append(m)
m.start()
s = yoloMthread()
jobs.append(s)
s.start()
for j in jobs:
    j.join()
Only one job is working that is yoloS the M gives error. I am new at TensorRT and thanks for any help!
You will need to handle the CUDA context push/pop when running TensorRT in thread.
Please find below comment for an example:
