Parameters gets broken when passing to __host__ function in .cu
Compiler: MSVC 2008
CUDA SDK: 2.2
Hi there, I am still struggling with the SDK upgrade… :-(
Currently, I have all parameters screwed up after I call any function in .cu
Here is code call:
init_md5_cuda(&(data->gpu), g->hash_i, perm::charset, perm::charset_len);
000000014000D305  mov		 rdx,qword ptr [g (140122D10h)]
000000014000D30C  add		 rdx,0D180h
000000014000D313  mov		 rcx,qword ptr [data]
000000014000D31B  add		 rcx,0A0h
000000014000D322  mov		 r9d,dword ptr [perm::charset_len (1401227BCh)]
000000014000D329  lea		 r8,[perm::charset (140122800h)]
000000014000D330  call		init_md5_cuda (14002E210h)
Here is how parameters are decoded:
000000014002E210  mov		 qword ptr [rsp+8],rbx
000000014002E215  mov		 qword ptr [rsp+10h],rsi
000000014002E21A  push		rdi
000000014002E21B  sub		 rsp,30h
000000014002E21F  mov		 edi,r9d
	cudaMemcpy("target_hash", hash_i, sizeof(int)*4, cudaMemcpyHostToDevice);
000000014002E222  mov		 r9d,1
000000014002E228  mov		 rsi,r8
000000014002E22B  mov		 rbx,rcx
000000014002E22E  lea		 rcx,[string "target_hash" (1400E36A8h)]
000000014002E235  lea		 r8d,[r9+0Fh]
000000014002E239  call		cudaMemcpy (14002E63Ch)
init_md5_cuda is extern “C”.
It passes values via registers, and tries to fetch them from stack :-S Not sure why :-S
It’s extern “C” - it should be all stack :-S
Same with 2.3
Not sure I understand your problem.
extern “C” doesn’t say anything about the way of passing parameters (it is architecture-dependent, OS-dependant, compiler-dependent and compiler-flags-dependent). It just means that the function is to be named according to C rules, not C++. So no name mangling, and no overload and template support.
Your code looks correct and in accordance with VS2008 calling convention for x64:
http://msdn.microsoft.com/en-us/library/zthk2dkh.aspx
Maybe you should check the compiler options that were used for both your .cu file and .cpp file and make sure they are compatible…
I’ve did a workaround by specifying __fastcall in .cu and in the headers. :-S
