Parameters in dewrapping app
xavier
• DeepStream Version
6.0
4.6
• TensorRT Version
TRT 8.0.1
10.2
For this dewrapping app, may I know where to get these infos? Any suggestions?
* top-angle - Top Field of View Angle, in degrees
* bottom-angle - Bottom Field of View Angle, in degrees
* pitch - Viewing parameter Pitch, in degrees
* yaw - Viewing parameter Yaw, in degrees
* roll - Viewing parameter Roll, in degrees
* focal length - Focal Lenght of camera lens, in pixels per radian
* width - dewarped surface width
* height - dewarped surface height
Do you want to get it from the code? You should set these infos to the config file. It isn’t got from the code.
You can refer the link below:
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvdewarper.html
My question is these are the parameters which manufactures of 360 camera has to provide or user has to calibrate or from where I have to take from? Any suggestions?
You could get it from the 360 camera.
