• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version: 5.0
• TensorRT Version 7.1.3.4
• NVIDIA GPU Driver Version (valid for GPU only) 440.33.01
• Issue Type( questions, new requirements, bugs) questions
• How to reproduce the issue ?
I want to write a custom plugin. The size of the buffer will be changed in the plugin, so I’m not using transform_ip but transform. I found that therefore dsexample is of limited use. I have problems generating valid output buffers.
static GstFlowReturn
gst_generateseq_transform (GstBaseTransform * btrans, GstBuffer * inbuf, GstBuffer * outbuf)
GstGenerateSeq *generateseq = GST_GENERATESEQ (btrans);
GstMapInfo in_map_info, out_map_info;
GstFlowReturn flow_ret = GST_FLOW_ERROR;
//gdouble scale_ratio = 1.0;
//GenerateSeqOutput *output;
NvBufSurface *surface = NULL;
NvBufSurface *outsurface = NULL;
NvDsBatchMeta *batch_meta = NULL;
NvDsFrameMeta *frame_meta = NULL;
NvDsMeta *meta = NULL;
guint i = 0;
int width, height, r;
NvBufSurface *output_surface;
NvBufSurfaceCreateParams params;
int batch_size = 1;
generateseq->frame_num++;
g_print("mapping\n");
memset (&in_map_info, 0, sizeof (in_map_info));
if (!gst_buffer_map (inbuf, &in_map_info, GST_MAP_READ)) {
g_print ("Error: Failed to map gst buffer\n");
goto error;
nvds_set_input_system_timestamp (inbuf, GST_ELEMENT_NAME (generateseq));
surface = (NvBufSurface *) in_map_info.data;
std::cout << "num surfaces " << surface->batchSize << std::endl;
params.gpuId = surface->gpuId;
params.width = 100;
params.height = 100;
params.size = 0;
params.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
params.layout = NVBUF_LAYOUT_PITCH;
params.memType = NVBUF_MEM_CUDA_UNIFIED;
r = NvBufSurfaceCreate(&output_surface, batch_size, ¶ms);
std::cout << r << std::endl;
///* read some infos for debugging
std::cout << "-- new surface " << std::endl;
std::cout << "batch info " << std::endl;
std::cout << "mem type " << output_surface->memType << std::endl;
std::cout << "out size " << params.size << std::endl;
std::cout << "out size " << output_surface->surfaceList[0].dataSize << std::endl;
std::cout << "dataPtr " << output_surface->surfaceList[0].dataPtr << std::endl;
std::cout << "mappedAddr " << output_surface->surfaceList[0].mappedAddr.addr[0] << std::endl;
outbuf = gst_buffer_new_wrapped_full (GST_MEMORY_FLAG_ZERO_PREFIXED,
output_surface,
sizeof(NvBufSurface), 0,
sizeof(NvBufSurface), NULL, NULL);
memset (&out_map_info, 0, sizeof (out_map_info));
if (!gst_buffer_map (outbuf, &out_map_info, GST_MAP_READWRITE)) {
g_print ("Error: Failed to out map gst buffer\n");
goto error;
outsurface = (NvBufSurface *) out_map_info.data;
NvBufSurfaceMemSet(outsurface, 0, 0, 0);
g_print("surface batchsize %u\n", outsurface->batchSize);
flow_ret = GST_FLOW_OK;
error:
nvds_set_output_system_timestamp (outbuf, GST_ELEMENT_NAME (generateseq));
gst_buffer_unmap (inbuf, &in_map_info);
gst_buffer_unmap (outbuf, &out_map_info);
g_print("exit\n");
return flow_ret;
When I map the created buffer with gst_buffer_map, I can read out the correct number of surfaces NvBufSurfaceCreate. I then return the buffer associated to this surface.
For testing, I duplicated the element generateseq in my pipline
.... ! generateseq ! generateseq ! ...
The second element outputs the following when receiving the buffer from the first element and then crashes.
num surfaces 2432761856
Cuda failure: status=101
-1
-- new surface
batch info
Caught SIGSEGV
I was expecting one surface. I assume, somehow the allocated buffers were freed? I also assume that I don’t have to sync the surface from GPU to CPU, since I’m not doing any CPU operations on it? What am I doing wrong?
