when i use static array like
integer, dimension(10,10), device :: arr2
instead of
integer, dimension(:,:), allocatable, device :: arr2
the code below works fine.
module test_mod
use cudafor
real, dimension(10,10), device :: arr1
integer, dimension(:,:),allocatable, device :: arr2
! integer, dimension(10,10), device :: arr2
contains
attributes(global) subroutine doOnGPU()
integer, value :: i, j
i = threadIdx%x
do j = 1, 10
arr1(i,j) = i +j/0.5d0
arr1(i,j) = i + j + arr1(arr2(i,i), j)
enddo
end subroutine doOnGPU
subroutine doOnCPU()
allocate(arr2(10,10))
arr2 = 1;
call doOnGPU<<<1, 10>>>()
end subroutine doOnCPU
end module test_mod
program test1
use test_mod
call doOnCPU()
end program test1
However, when I use allocatable, I get this warning
/tmp/pgcudaforVr5cnWS3-zwQ.gpu: In function `doongpu’:
/tmp/pgcudaforVr5cnWS3-zwQ.gpu:17: warning: cast to pointer from integer of different size
/tmp/pgcudaforVr5cnWS3-zwQ.gpu(17): Warning: Cannot tell what pointer points to, assuming global memory space
Could you please tell me why?
Thanks,
Tuan
