I’m trying to use allocatable arrays inside user-defined types, with the whole data structure residing on the GPU.
Here’s my module declaration:
! This module contains definitions for data structures and the data
! stored on the device
module GPU_variables
use cudafor
type :: data_str_def
! single number quantities
integer :: i, j
real(kind=8) :: a
! Arrays
real(kind=8), allocatable :: b(:)
real(kind=8), allocatable :: c(:,:)
real(kind=8), allocatable :: d(:,:,:)
real(kind=8), allocatable :: e(:,:,:,:)
end type data_str_def
! Actual data is here
type(data_str_def), device, allocatable :: data_str(:)
contains
! subroutine to allocate memory
subroutine allocate_mem(n1)
implicit none
integer, intent(in) :: n1
call deallocate_mem()
write(*,*) 'works here'
allocate(data_str(n1))
write(*,*) 'what about allocating memory?'
allocate(data_str(n1) % b(10))
write(*,*) 'success!'
return
end subroutine allocate_mem
! subroutine to deallocate memory
subroutine deallocate_mem()
implicit none
if(allocated(data_str)) deallocate(data_str)
return
end subroutine deallocate_mem
end module GPU_variables
Calling program is
! main program
program gpu_test
use gpu_variables
implicit none
! local variables
integer :: i, j, n
! allocate data
n = 2 ! number of data structures
call allocate_mem(n)
! dallocate device data structures and exit
end program
module file is called gpu_modules.F90
mainprogram file is called gpu_test.F90
compilation command is
pgfortran -Mcuda=cc5x *.F90
Terminal output is
$ ./a.out
works here
The idea was to use GPU memory in modules so that subroutines have access to the data, and data structures are a nice way to organize variable-sized arrays.
Am I doing something obviously wrong? Please help!
