i have bought a alienware area-51m and have been trying to get my iGPU working on my laptop screen
but i always gets a totally black screen.i have been trying to use prime and bumblebee but can not manage to make it work.this type of laptop have a desktop gpu build in it and using its screen output to the laptop screen and i believe this is not the way it is done with other laptops.i have no problem
using the nvidia gpu but it is to hungry when i am on the fly.my hopes is to use the iGPU to handle the Desktop Environment and having the nvidia GPU for games.
You have both xorg.conf in place so the options add up and nothing works. It’s either or. Delete /etc/X11/xorg.conf and replace it with the offloading one. You shouldn’t put config files containing specific Device and ServerLayout sections in xorg.conf.d.
I don’t know why you didn’t just copy over you already correct offload config.
Please add the busid to the nvidia section.
Remove the DRI setting from igpu device setion
keyboard and mouse sections are not necessary on modern xorg.
Ok, the setup is correct now but I only now notice that the internal display is connected to the nvidia gpu, you’ll probably have to switch to optimus mode in bios. Please check for an option there.
