patch for 387.34 and Linux 4.15.0-rc1
With the recent timer changes in 4.15.0-rc1, the nvidia build needed to be updated to use the new timer functions.
The below patch also contains everything else needed to build the latest nvidia kernel modules under 4.15 as well.
Please note that this is a patch that is formatted to be compatible with DKMS so it will be in the -p1 format.
diff -u -r NVIDIA-Linux-x86_64-387.22/kernel/nvidia-drm/nvidia-drm-connector.c NVIDIA-Linux-x86_64-387.22.patched/kernel/nvidia-drm/nvidia-drm-connector.c
--- a/nvidia-drm/nvidia-drm-connector.c	2017-10-26 09:29:25.000000000 +0200
+++ b/nvidia-drm/nvidia-drm-connector.c	2017-11-16 20:15:35.123121624 +0100
@@ -107,7 +107,7 @@
             break;
-        encoder = drm_encoder_find(dev, id);
+        encoder = drm_encoder_find(dev, NULL, id);
         if (encoder == NULL)
diff -u -r NVIDIA-Linux-x86_64-387.22/kernel/nvidia-drm/nvidia-drm-crtc.c NVIDIA-Linux-x86_64-387.22.patched/kernel/nvidia-drm/nvidia-drm-crtc.c
--- a/nvidia-drm/nvidia-drm-crtc.c	2017-10-26 09:29:25.000000000 +0200
+++ b/nvidia-drm/nvidia-drm-crtc.c	2017-11-17 01:06:06.298997404 +0100
@@ -434,7 +434,7 @@
         goto done;
-    crtc = drm_crtc_find(dev, params->crtc_id);
+    crtc = drm_crtc_find(dev, NULL, params->crtc_id);
     if (!crtc) {
         NV_DRM_DEV_LOG_DEBUG(nv_dev, "Unknown CRTC ID %d\n", params->crtc_id);
         ret = -ENOENT;
diff -u -r NVIDIA-Linux-x86_64-387.22/kernel/nvidia-drm/nvidia-drm-linux.c NVIDIA-Linux-x86_64-387.22.patched/kernel/nvidia-drm/nvidia-drm-linux.c
--- a/nvidia-drm/nvidia-drm-linux.c	2017-10-26 09:29:26.000000000 +0200
+++ b/nvidia-drm/nvidia-drm-linux.c	2017-11-14 01:47:40.815680166 +0100
@@ -185,7 +185,7 @@
 module_exit(nv_linux_drm_exit);
 #if defined(MODULE_LICENSE)
-  MODULE_LICENSE("MIT");
+  MODULE_LICENSE("GPL");
 #endif
 #if defined(MODULE_INFO)
   MODULE_INFO(supported, "external");
diff -u -r NVIDIA-Linux-x86_64-387.22/kernel/nvidia-drm/nvidia-drm-modeset.c NVIDIA-Linux-x86_64-387.22.patched/kernel/nvidia-drm/nvidia-drm-modeset.c
--- a/nvidia-drm/nvidia-drm-modeset.c	2017-10-26 09:29:25.000000000 +0200
+++ b/nvidia-drm/nvidia-drm-modeset.c	2017-11-17 01:16:51.188958966 +0100
@@ -252,7 +252,7 @@
     /* Loops over all crtcs and fill head configuration for changes */
-    for_each_crtc_in_state(state, crtc, crtc_state, i)
+    for_each_new_crtc_in_state(state, crtc, crtc_state, i)
         struct nvidia_drm_crtc *nv_crtc;
         struct NvKmsKapiHeadRequestedConfig *head_requested_config;
@@ -303,7 +303,7 @@
             head_requested_config->flags.displaysChanged = NV_TRUE;
-            for_each_connector_in_state(state, connector, connector_state, j) {
+            for_each_new_connector_in_state(state, connector, connector_state, j) {
                 if (connector_state->crtc != crtc) {
                     continue;
@@ -324,7 +324,7 @@
     /* Loops over all planes and fill plane configuration for changes */
-    for_each_plane_in_state(state, plane, plane_state, i)
+    for_each_new_plane_in_state(state, plane, plane_state, i)
@@ -634,7 +634,7 @@
          nvidia_drm_write_combine_flush();
-    for_each_crtc_in_state(state, crtc, crtc_state, i) {
+    for_each_new_crtc_in_state(state, crtc, crtc_state, i) {
         struct nvidia_drm_crtc *nv_crtc = DRM_CRTC_TO_NV_CRTC(crtc);
         struct nv_drm_crtc_state *nv_crtc_state = to_nv_crtc_state(crtc->state);
         struct nv_drm_flip *nv_flip = nv_crtc_state->nv_flip;
diff -u -r NVIDIA-Linux-x86_64-387.22/kernel/nvidia-uvm/uvm8_va_block.c NVIDIA-Linux-x86_64-387.22.patched/kernel/nvidia-uvm/uvm8_va_block.c
--- a/nvidia-uvm/uvm8_va_block.c	2017-10-26 09:29:23.000000000 +0200
+++ b/nvidia-uvm/uvm8_va_block.c	2017-11-14 01:43:56.176693556 +0100
@@ -36,6 +36,8 @@
 #include "uvm8_perf_prefetch.h"
 #include "uvm8_mem.h"
+#include <linux/sched/task_stack.h>
 typedef enum
     BLOCK_PTE_OP_MAP,
--- a/nvidia/nv.c	2017-11-25 07:14:29.000000000 -0600
+++ b/nvidia/nv.c	2017-11-27 00:09:01.948814571 -0600
@@ -320,7 +320,7 @@
 #else
 static irqreturn_t   nvidia_isr             (int, void *);
 #endif
-static void          nvidia_rc_timer        (unsigned long);
+static void          nvidia_rc_timer        (struct timer_list *t);
 static int           nvidia_ctl_open        (struct inode *, struct file *);
 static int           nvidia_ctl_close       (struct inode *, struct file *);
@@ -2472,10 +2472,10 @@
 static void
 nvidia_rc_timer(
-    unsigned long data
+    struct timer_list *t
-    nv_linux_state_t *nvl = (nv_linux_state_t *) data;
+    nv_linux_state_t *nvl = from_timer(nvl, t, rc_timer);
     nv_state_t *nv = NV_STATE_PTR(nvl);
     nvidia_stack_t *sp = nvl->sp[NV_DEV_STACK_TIMER];
@@ -3386,9 +3386,7 @@
         return -1;
     nv_printf(NV_DBG_INFO, "NVRM: initializing rc timer\n");
-    init_timer(&nvl->rc_timer);
-    nvl->rc_timer.function = nvidia_rc_timer;
-    nvl->rc_timer.data = (unsigned long) nvl;
+    timer_setup(&nvl->rc_timer, nvidia_rc_timer, 0);
     nv->rc_timer_enabled = 1;
     mod_timer(&nvl->rc_timer, jiffies + HZ); /* set our timeout for 1 second */
     nv_printf(NV_DBG_INFO, "NVRM: rc timer initialized\n");
--- a/nvidia-modeset/nvidia-modeset-linux.c	2017-11-25 07:14:29.000000000 -0600
+++ b/nvidia-modeset/nvidia-modeset-linux.c	2017-11-27 00:19:36.006798982 -0600
@@ -566,9 +566,9 @@
     WARN_ON(!ret);
-static void nvkms_timer_callback(unsigned long arg)
+static void nvkms_timer_callback(struct timer_list *t)
-    struct nvkms_timer_t *timer = (struct nvkms_timer_t *) arg;
+    struct nvkms_timer_t *timer = from_timer(timer, t, kernel_timer);
     /* In softirq context, so schedule nvkms_kthread_q_callback(). */
     nvkms_queue_work(&nvkms_kthread_q, &timer->nv_kthread_q_item);
@@ -606,10 +606,8 @@
         timer->kernel_timer_created = NV_FALSE;
     } else {
-        init_timer(&timer->kernel_timer);
+        timer_setup(&timer->kernel_timer, nvkms_timer_callback, 0);
         timer->kernel_timer_created = NV_TRUE;
-        timer->kernel_timer.function = nvkms_timer_callback;
-        timer->kernel_timer.data = (unsigned long) timer;
         mod_timer(&timer->kernel_timer, jiffies + NVKMS_USECS_TO_JIFFIES(usec));
     spin_unlock_irqrestore(&nvkms_timers.lock, flags);
It can also be downloaded directly here:
https://jons.org/buildfix_kernel_4.15.patch.txt
Nice, reserved todays evening to fix that timer update because it looked non trivial at first glance on my phone, but you worked it out first (need to learn to read cocci semantic patches).
noob question.
how do i apply patch, is it for kernel or driver.
I have installed the newest driver for NVIDIA Corporation C67 [GeForce 7150M / nForce 630M]
it will not install on 4.15.x or 4.15.0rcX
i can run nouveau but not nvidia-304 ( standard linux non-free distro ) or your self installing custom driver @ 304.1370 https://www.geforce.com/drivers/results/123709
is there patch install instructions somewhere ?
The 387.34 (ubuntu bundled) compiles fine on 4.15.9 with this patch applied. PRIME synchronization, however, doesn’t work. A very similar patch is available to 390.25 which allows PRIME to work - but 390.25 has a ton of other bugs of it’s own. EDIT: comparing with the 390.25 I see that conftest patch was missing. Apppend to the above patch the following block and prime will work:
--- a/conftest.sh	2018-03-12 14:06:39.644221598 -0300
+++ b/conftest.sh	2018-03-12 14:07:45.632387089 -0300
@@ -2107,6 +2107,7 @@
             #endif
             #include <drm/drm_atomic.h>
             #include <drm/drm_atomic_helper.h>
+            #include <linux/version.h>
             #if !defined(CONFIG_DRM) && !defined(CONFIG_DRM_MODULE)
             #error DRM not enabled
             #endif
@@ -2128,9 +2129,12 @@
                 /* 2014-12-18 88a48e297b3a3bac6022c03babfb038f1a886cea */
                 i = DRIVER_ATOMIC;
+		#if LINUX_VERSION_CODE < KERNEL_VERSION(4, 15, 0)
                 /* 2015-04-10 df63b9994eaf942afcdb946d27a28661d7dfbf2a */
                 for_each_crtc_in_state(s, c, cs, i) { }
+                #else
+                for_each_new_crtc_in_state(s, c, cs, i) {}
+                #endif
             compile_check_conftest "$CODE" "NV_DRM_ATOMIC_MODESET_AVAILABLE" "" "generic"
