I had to stay at 495.46 since drivers after 510.xx couldn’t adjust the screen backlight, but the 495 driver are not compatible with newer kernel versions.
» sudo pacman -U nvidia-dkms-495.46-2-x86_64.pkg.tar.zst nvidia-utils-495.46-2-x86_64.pkg.tar.zst
loading packages...
warning: nvidia-dkms-495.46-2 is up to date -- reinstalling
warning: nvidia-utils-495.46-2 is up to date -- reinstalling
resolving dependencies...
looking for conflicting packages...
Package (2) Old Version New Version Net Change
nvidia-dkms 495.46-2 495.46-2 0.00 MiB
nvidia-utils 495.46-2 495.46-2 0.00 MiB
Total Installed Size: 485.24 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n]
(2/2) checking keys in keyring [################################] 100%
(2/2) checking package integrity [################################] 100%
(2/2) loading package files [################################] 100%
(2/2) checking for file conflicts [################################] 100%
(2/2) checking available disk space [################################] 100%
:: Running pre-transaction hooks...
(1/1) Remove upgraded DKMS modules
==> dkms remove --no-depmod nvidia/495.46 -k 5.15.59-1-lts
:: Processing package changes...
(1/2) reinstalling nvidia-utils [################################] 100%
If you run into trouble with CUDA not being available, run nvidia-modprobe first.
(2/2) reinstalling nvidia-dkms [################################] 100%
:: Running post-transaction hooks...
(1/5) Creating system user accounts...
(2/5) Reloading system manager configuration...
(3/5) Reloading device manager configuration...
(4/5) Arming ConditionNeedsUpdate...
(5/5) Install DKMS modules
==> dkms install --no-depmod nvidia/495.46 -k 5.15.59-1-lts
==> dkms install --no-depmod nvidia/495.46 -k 5.18.16-arch1-1
Error! Bad return status for module build on kernel: 5.18.16-arch1-1 (x86_64)
Consult /var/lib/dkms/nvidia/495.46/build/make.log for more information.
==> WARNING: `dkms install --no-depmod nvidia/495.46 -k 5.18.16-arch1-1' exited 10
==> depmod 5.15.59-1-lts
» cat /var/lib/dkms/nvidia/495.46/build/make.log
DKMS make.log for nvidia-495.46 for kernel 5.18.16-arch1-1 (x86_64)
Sat Aug 6 09:51:52 PM CST 2022
make[1]: Entering directory '/usr/lib/modules/5.18.16-arch1-1/build'
warning: the compiler differs from the one used to build the kernel
The kernel was built by: gcc (GCC) 12.1.1 20220730
You are using: cc (GCC) 12.1.1 20220730
SYMLINK /var/lib/dkms/nvidia/495.46/build/nvidia/nv-kernel.o
SYMLINK /var/lib/dkms/nvidia/495.46/build/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: hash__remap_4k_pfn
CONFTEST: set_pages_uc
CONFTEST: list_is_first
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: set_pages_array_uc
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: sg_alloc_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: dma_attr_macros
CONFTEST: dma_map_page_attrs
CONFTEST: write_cr4
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: of_get_property
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: register_cpu_notifier
CONFTEST: pci_remove_bus_device
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: backlight_device_register
CONFTEST: get_backlight_device_by_name
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: kernel_read_has_pointer_pos_arg
CONFTEST: kernel_write
CONFTEST: kthread_create_on_node
CONFTEST: of_find_matching_node
CONFTEST: dev_is_pci
CONFTEST: dma_direct_map_resource
CONFTEST: tegra_get_platform
CONFTEST: tegra_bpmp_send_receive
CONFTEST: flush_cache_all
CONFTEST: vmf_insert_pfn
CONFTEST: jiffies_to_timespec
CONFTEST: ktime_get_raw_ts64
CONFTEST: ktime_get_real_ts64
CONFTEST: full_name_hash
CONFTEST: hlist_for_each_entry
CONFTEST: pci_enable_atomic_ops_to_root
CONFTEST: vga_tryget
CONFTEST: pgprot_decrypted
CONFTEST: iterate_fd
CONFTEST: seq_read_iter
CONFTEST: sg_page_iter_page
CONFTEST: unsafe_follow_pfn
CONFTEST: drm_gem_object_get
CONFTEST: drm_gem_object_put_unlocked
CONFTEST: set_close_on_exec
CONFTEST: add_memory_driver_managed
CONFTEST: device_property_read_u64
CONFTEST: devm_of_platform_populate
CONFTEST: of_dma_configure
CONFTEST: of_property_count_elems_of_size
CONFTEST: of_property_read_variable_u8_array
CONFTEST: i2c_new_client_device
CONFTEST: i2c_unregister_device
CONFTEST: of_get_named_gpio
CONFTEST: devm_gpio_request_one
CONFTEST: gpio_direction_input
CONFTEST: gpio_direction_output
CONFTEST: gpio_set_value
CONFTEST: gpio_get_value
CONFTEST: gpio_to_irq
CONFTEST: icc_get
CONFTEST: icc_put
CONFTEST: icc_set_bw
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: cpumask_of_node
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: get_user_pages_remote
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: drm_framebuffer_get
CONFTEST: drm_dev_put
CONFTEST: drm_format_num_planes
CONFTEST: drm_connector_for_each_possible_encoder
CONFTEST: drm_rotation_available
CONFTEST: drm_vma_offset_exact_lookup_locked
CONFTEST: nvhost_dma_fence_unpack
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_gpl_sme_active
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: is_export_symbol_present___close_fd
CONFTEST: is_export_symbol_present_close_fd
CONFTEST: is_export_symbol_present_get_unused_fd
CONFTEST: is_export_symbol_present_get_unused_fd_flags
CONFTEST: is_export_symbol_present_nvhost_get_default_device
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_byte_offset
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_aperture
CONFTEST: is_export_symbol_present_tegra_dce_register_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_unregister_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_client_ipc_send_recv
CONFTEST: is_export_symbol_present_dram_clk_to_mc_clk
CONFTEST: is_export_symbol_present_get_dram_num_channels
CONFTEST: is_export_symbol_present_tegra_dram_types
CONFTEST: is_export_symbol_present_kthread_create_on_node
CONFTEST: acpi_op_remove
CONFTEST: file_operations
CONFTEST: file_inode
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: vm_insert_pfn_prot
CONFTEST: vmf_insert_pfn_prot
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: vmbus_channel_has_ringbuffer_page
CONFTEST: device_driver_of_match_table
CONFTEST: device_of_node
CONFTEST: node_states_n_memory
CONFTEST: kmem_cache_has_kobj_remove_work
CONFTEST: sysfs_slab_unlink
CONFTEST: proc_ops
CONFTEST: timespec64
CONFTEST: vmalloc_has_pgprot_t_arg
CONFTEST: acpi_fadt_low_power_s0
CONFTEST: mm_has_mmap_lock
CONFTEST: pci_channel_state
CONFTEST: pci_dev_has_ats_enabled
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_fault_t
CONFTEST: mmu_notifier_ops_invalidate_range
CONFTEST: migrate_vma_setup
CONFTEST: migrate_vma_added_flags
CONFTEST: make_device_exclusive_range
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_device_list
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_init_function_args
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_atomic_helper_plane_destroy_state_has_plane_arg
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
CONFTEST: drm_driver_prime_flag_present
CONFTEST: drm_gem_object_has_resv
CONFTEST: drm_crtc_state_has_async_flip
CONFTEST: drm_crtc_state_has_pageflip_flags
CONFTEST: drm_format_modifiers_present
CONFTEST: drm_vma_node_is_allowed_has_tag_arg
CONFTEST: drm_vma_offset_node_has_readonly
CONFTEST: drm_display_mode_has_vrefresh
CONFTEST: drm_driver_master_set_has_int_return_type
CONFTEST: drm_driver_has_gem_free_object
CONFTEST: drm_prime_pages_to_sg_has_drm_device_arg
CONFTEST: drm_driver_has_gem_prime_callbacks
CONFTEST: drm_crtc_atomic_check_has_atomic_state_arg
CONFTEST: drm_gem_object_vmap_has_map_arg
CONFTEST: drm_plane_atomic_check_has_atomic_state_arg
CONFTEST: drm_device_has_pdev
CONFTEST: drm_crtc_state_has_no_vblank
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: nvidia_grid_csp_build
CONFTEST: pm_runtime_available
CONFTEST: pci_class_multimedia_hd_audio
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CONFTEST: drm_alpha_blending_available
CONFTEST: ib_peer_memory_symbols
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/nv.o
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/nv-pci.o
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/nv-acpi.o
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/nv-dma.o
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/nv-cray.o
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/nv-i2c.o
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/nv-mmap.o
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/nv-p2p.o
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/nv-pat.o
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs.o
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs-utils.o
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/nv-usermap.o
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/nv-vm.o
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/nv-vtophys.o
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/os-interface.o
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/os-mlock.o
CC [M] /var/lib/dkms/nvidia/495.46/build/nvidia/os-pci.o
In file included from /var/lib/dkms/nvidia/495.46/build/common/inc/nv-procfs.h:26,
from /var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs.c:31:
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs.c: In function ‘nv_procfs_open_gpu_info’:
/var/lib/dkms/nvidia/495.46/build/common/inc/nv-procfs-utils.h:104:29: error: implicit declaration of function ‘PDE’ [-Werror=implicit-function-declaration]
104 | # define NV_PDE_DATA(inode) PDE(inode)->data
/var/lib/dkms/nvidia/495.46/build/common/inc/nv-procfs-utils.h:126:27: note: in expansion of macro ‘NV_PDE_DATA’
126 | NV_PDE_DATA(inode)); \
/var/lib/dkms/nvidia/495.46/build/common/inc/nv-procfs-utils.h:150:5: note: in expansion of macro ‘NV_DEFINE_SINGLE_PROCFS_FILE_HELPER’
150 | NV_DEFINE_SINGLE_PROCFS_FILE_HELPER(name, open_callback, close_callback)\
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs.c:38:5: note: in expansion of macro ‘NV_DEFINE_SINGLE_PROCFS_FILE_READ_ONLY’
38 | NV_DEFINE_SINGLE_PROCFS_FILE_READ_ONLY(name, \
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs.c:192:1: note: in expansion of macro ‘NV_DEFINE_SINGLE_NVRM_PROCFS_FILE’
192 | NV_DEFINE_SINGLE_NVRM_PROCFS_FILE(gpu_info);
/var/lib/dkms/nvidia/495.46/build/common/inc/nv-procfs-utils.h:104:39: error: invalid type argument of ‘->’ (have ‘int’)
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs.c: In function ‘nv_procfs_open_power’:
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs.c:244:1: note: in expansion of macro ‘NV_DEFINE_SINGLE_NVRM_PROCFS_FILE’
244 | NV_DEFINE_SINGLE_NVRM_PROCFS_FILE(power);
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs.c: In function ‘nv_procfs_open_version’:
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-dma.c:986: warning: "IMPORT_SGT_STUBS_NEEDED" redefined
986 | #define IMPORT_SGT_STUBS_NEEDED 0
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs.c:258:1: note: in expansion of macro ‘NV_DEFINE_SINGLE_NVRM_PROCFS_FILE’
258 | NV_DEFINE_SINGLE_NVRM_PROCFS_FILE(version);
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-dma.c:980: note: this is the location of the previous definition
980 | #define IMPORT_SGT_STUBS_NEEDED 1
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs.c: In function ‘nv_procfs_open_file’:
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs.c:303:16: note: in expansion of macro ‘NV_PDE_DATA’
303 | nvpp->nv = NV_PDE_DATA(inode);
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs.c: In function ‘nv_procfs_open_params’:
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs.c:469:1: note: in expansion of macro ‘NV_DEFINE_SINGLE_NVRM_PROCFS_FILE’
469 | NV_DEFINE_SINGLE_NVRM_PROCFS_FILE(params);
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs.c: In function ‘nv_procfs_open_text_file’:
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs.c:1304:1: note: in expansion of macro ‘NV_DEFINE_SINGLE_NVRM_PROCFS_FILE’
1304 | NV_DEFINE_SINGLE_NVRM_PROCFS_FILE(text_file);
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-mmap.c: In function ‘nv_encode_caching’:
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-mmap.c:334:16: warning: this statement may fall through [-Wimplicit-fallthrough=]
334 | if (NV_ALLOW_CACHING(memory_type))
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-mmap.c:337:9: note: here
337 | default:
cc1: some warnings being treated as errors
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-acpi.c: In function ‘nv_acpi_methods_init’:
/var/lib/dkms/nvidia/495.46/build/nvidia/nv-acpi.c:655:22: error: implicit declaration of function ‘acpi_bus_get_device’; did you mean ‘acpi_is_pnp_device’? [-Werror=implicit-function-declaration]
655 | retVal = acpi_bus_get_device(nvif_parent_gpu_handle, &device);
| acpi_is_pnp_device
make[2]: *** [scripts/Makefile.build:289: /var/lib/dkms/nvidia/495.46/build/nvidia/nv-procfs.o] Error 1
make[2]: *** Waiting for unfinished jobs....
/var/lib/dkms/nvidia/495.46/build/nvidia/nv.c: In function ‘nv_set_dma_address_size’:
/var/lib/dkms/nvidia/495.46/build/nvidia/nv.c:2891:9: error: implicit declaration of function ‘pci_set_dma_mask’; did you mean ‘ipi_send_mask’? [-Werror=implicit-function-declaration]
2891 | pci_set_dma_mask(nvl->pci_dev, new_mask);
| ipi_send_mask
/var/lib/dkms/nvidia/495.46/build/nvidia/nv.c:2897:9: error: implicit declaration of function ‘pci_set_consistent_dma_mask’ [-Werror=implicit-function-declaration]
2897 | pci_set_consistent_dma_mask(nvl->pci_dev, new_mask);
make[2]: *** [scripts/Makefile.build:289: /var/lib/dkms/nvidia/495.46/build/nvidia/nv-acpi.o] Error 1
make[2]: *** [scripts/Makefile.build:289: /var/lib/dkms/nvidia/495.46/build/nvidia/nv.o] Error 1
make[1]: *** [Makefile:1838: /var/lib/dkms/nvidia/495.46/build] Error 2
make[1]: Leaving directory '/usr/lib/modules/5.18.16-arch1-1/build'
make: *** [Makefile:80: modules] Error 2
