Hello all,
I’m trying to get K80 passthrough to a KVM. The VM isn’t starting at all.
Passthrough is working fine with mellanox IB card.
Getting the error in libvirtd qemu logs:
char device redirected to /dev/pts/1
assigned_dev_register_regions: Error: Couldn't mmap 0x0!
2017-12-01T22:43:28.524367Z qemu-kvm: -device pci-assign,host=86:00.0,id=hostdev0,configfd=23,bus=pci.0,addr=0x5: Device 'pci-assign' could not be initialized
Have intel_iommu enabled:
[root@comet-31-20 ~]# cat /proc/cmdline
ro root=UUID=31413545-96ee-483d-9fae-828669546718 rd_NO_LUKS rd_NO_LVM LANG=en_US.UTF-8 rd_NO_MD SYSFONT=latarcyrheb-sun16 KEYBOARDTYPE=pc KEYTABLE=us rd_NO_DM rhgb quiet intel_iommu=on pci=realloc rdblacklist=nvidia
The device is detached from the host:
# readlink /sys/bus/pci/devices/0000\:86\:00.0/driver
../../../../../../bus/pci/drivers/pci-stub
My VM XML:
<domain type='kvm'>
<name>vm-sc17k8s-00</name>
<uuid>c6fb015d-2283-7d73-8ef3-4add97bf9e4e</uuid>
<memory unit='KiB'>112640000</memory>
<currentMemory unit='KiB'>112640000</currentMemory>
<memoryBacking>
<nosharepages/>
</memoryBacking>
<vcpu placement='static'>24</vcpu>
<numatune>
<memory mode='strict' nodeset='0-1'/>
</numatune>
<os>
<type arch='x86_64' machine='rhel6.6.0'>hvm</type>
<boot dev='network'/>
<boot dev='hd'/>
<bootmenu enable='yes'/>
</os>
<features>
<acpi/>
<apic/>
<pae/>
</features>
<cpu mode='host-passthrough'>
</cpu>
<clock offset='utc'/>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<devices>
<emulator>/usr/libexec/qemu-kvm</emulator>
<disk type='block' device='disk'>
<driver name='qemu' type='raw'/>
<source dev='/dev/sdb'/>
<target dev='vda' bus='virtio'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0'/>
</disk>
<disk type='file' device='cdrom'>
<target dev='hda' bus='ide'/>
<readonly/>
<address type='drive' controller='0' bus='0' target='0' unit='0'/>
</disk>
<controller type='usb' index='0'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x2'/>
</controller>
<controller type='ide' index='0'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x1'/>
</controller>
<serial type='pty'>
<target port='0'/>
</serial>
<console type='pty'>
<target type='serial' port='0'/>
</console>
<input type='tablet' bus='usb'/>
<input type='mouse' bus='ps2'/>
<graphics type='vnc' port='-1' autoport='yes' keymap='en-us' passwd='55zPqpiCfa0FXtC3'/>
<video>
<model type='cirrus' vram='9216' heads='1'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0'/>
</video>
<hostdev mode='subsystem' type='pci' managed='yes'>
<source>
<address domain='0x0000' bus='0x86' slot='0x00' function='0x0'/>
</source>
<address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x0'/>
</hostdev>
<memballoon model='virtio'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x04' function='0x0'/>
</memballoon>
</devices>
</domain>
Starting command:
LC_ALL=C PATH=/sbin:/usr/sbin:/bin:/usr/bin QEMU_AUDIO_DRV=none /usr/libexec/qemu-kvm -name vm-sc17k8s-00 -S -M rhel6.6.0 -cpu host -enable-kvm -m 110000 -redhat-disable-KSM -realtime mlock=off -smp 24,sockets=24,cores=1,threads=1 -uuid c6fb015d-2283-7d73-8ef3-4add97bf9e4e -nodefconfig -nodefaults -chardev socket,id=charmonitor,path=/var/lib/libvirt/qemu/vm-sc17k8s-00.monitor,server,nowait -mon chardev=charmonitor,id=monitor,mode=control -rtc base=utc -no-shutdown -boot order=nc,menu=on -device piix3-usb-uhci,id=usb,bus=pci.0,addr=0x1.0x2 -drive file=/dev/sdb,if=none,id=drive-virtio-disk0,format=raw -device virtio-blk-pci,scsi=off,bus=pci.0,addr=0x3,drive=drive-virtio-disk0,id=virtio-disk0 -drive if=none,media=cdrom,id=drive-ide0-0-0,readonly=on,format=raw -device ide-drive,bus=ide.0,unit=0,drive=drive-ide0-0-0,id=ide0-0-0 -chardev pty,id=charserial0 -device isa-serial,chardev=charserial0,id=serial0 -device usb-tablet,id=input0 -vnc 127.0.0.1:0,password -k en-us -vga cirrus -device pci-assign,host=86:00.0,id=hostdev0,configfd=23,bus=pci.0,addr=0x5 -device virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x4 -msg timestamp=on
Kernel 2.6.32-696.10.3.el6.x86_64, CentOS 6.4, qemu-kvm 2:0.12.1.2-2.503.el6_9.3
