PCIe passthrough
I’m trying to do PCIe passthrough from host to Qemu-KVM.
I do see the WiFi card being added to an IOMMU group when booting up
But when trying to take control of the device I don’t see it available nor IOMMU compatible. lspci doesn’t return any IOMMU/SMMU capabilities when you run lspci -v | grep “IOMMU”
At the same time, when trying to list available PCI devices to use with virsh, none are displayed:
Even trying to use vfio-pci to take control of the PCIe doesn’t work, as explained in this post (ACS override patch to isolate target device from IOMMU group)
I’m also getting that same error, but as pointed out above, both PCI’s are being assigned to an IOMMU group.
Is there something missing on both approaches to make this work?
Appreciate the help
Please share more information about the PCIe device. And for reference, please execute lspci -vvv and share the prints.
hi DaneLLL,
I appreciate your response.
Here’s the output for lspci -vvv
PCI Bridge:
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad1 (rev a1) (prog-if 00 [Normal decode])
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 24
	Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
	I/O behind bridge: 00001000-00001fff [size=4K]
	Memory behind bridge: 40000000-400fffff [size=1M]
	Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff [disabled]
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
	BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16- MAbort- >Reset- FastB2B-
		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
	Capabilities: [40] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
		Address: 0000000000000000  Data: 0000
		Masking: 00000000  Pending: 00000000
	Capabilities: [70] Express (v2) Root Port (Slot-), MSI 00
		DevCap:	MaxPayload 256 bytes, PhantFunc 0
			ExtTag- RBE+
		DevCtl:	CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
			RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
			MaxPayload 128 bytes, MaxReadReq 512 bytes
		DevSta:	CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
		LnkCap:	Port #0, Speed 16GT/s, Width x1, ASPM not supported
			ClockPM- Surprise+ LLActRep+ BwNot+ ASPMOptComp+
		LnkCtl:	ASPM Disabled; RCB 64 bytes Disabled- CommClk-
			ExtSynch- ClockPM- AutWidDis- BWInt+ AutBWInt-
		LnkSta:	Speed 2.5GT/s (downgraded), Width x1 (ok)
			TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
		RootCap: CRSVisible+
		RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible+
		RootSta: PME ReqID 0000, PMEStatus- PMEPending-
		DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, NROPrPrP+, LTR+
			 10BitTagComp+, 10BitTagReq-, OBFF Not Supported, ExtFmt-, EETLPPrefix-
			 EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
			 FRS-, LN System CLS Not Supported, TPHComp-, ExtTPHComp-, ARIFwd-
			 AtomicOpsCap: Routing- 32bit- 64bit- 128bitCAS-
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
			 AtomicOpsCtl: ReqEn- EgressBlck-
		LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
			 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
			 Compliance De-emphasis: -6dB
		LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
			 EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
	Capabilities: [b0] MSI-X: Enable- Count=8 Masked-
		Vector table: BAR=2 offset=00000000
		PBA: BAR=2 offset=00010000
	Capabilities: [100 v2] Advanced Error Reporting
		UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UESvrt:	DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
		CEMsk:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
		AERCap:	First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
			MultHdrRecCap+ MultHdrRecEn- TLPPfxPres- HdrLogCap-
		HeaderLog: 00000000 00000000 00000000 00000000
		RootCmd: CERptEn+ NFERptEn+ FERptEn+
		RootSta: CERcvd- MultCERcvd- UERcvd- MultUERcvd-
			 FirstFatal- NonFatalMsg- FatalMsg- IntMsg 0
		ErrorSrc: ERR_COR: 0000 ERR_FATAL/NONFATAL: 0000
	Capabilities: [148 v1] Secondary PCI Express
		LnkCtl3: LnkEquIntrruptEn-, PerformEqu-
		LaneErrStat: 0
	Capabilities: [168 v1] Physical Layer 16.0 GT/s <?>
	Capabilities: [18c v1] Lane Margining at the Receiver <?>
	Capabilities: [1ac v1] L1 PM Substates
		L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2- ASPM_L1.1- L1_PM_Substates+
			  PortCommonModeRestoreTime=60us PortTPowerOnTime=40us
		L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
			   T_CommonMode=10us
		L1SubCtl2: T_PwrOn=10us
	Capabilities: [1bc v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
	Capabilities: [2bc v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
	Capabilities: [2f4 v1] Data Link Feature <?>
	Capabilities: [300 v1] Precision Time Measurement
		PTMCap: Requester:+ Responder:+ Root:+
		PTMClockGranularity: 16ns
		PTMControl: Enabled:- RootSelected:-
		PTMEffectiveGranularity: Unknown
	Capabilities: [30c v1] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
	Kernel driver in use: pcieport
Network Card:
0004:01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
	Subsystem: AzureWave RTL8822CE 802.11ac PCIe Wireless Network Adapter
	Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Region 0: I/O ports at 1000 [disabled] [size=256]
	Region 2: Memory at 1740000000 (64-bit, non-prefetchable) [disabled] [size=64K]
		Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
		Status: D3 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [70] Express (v2) Endpoint, MSI 00
		DevCap:	MaxPayload 128 bytes, PhantFunc 0, Latency L0s <4us, L1 <64us
			ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
		DevCtl:	CorrErr- NonFatalErr- FatalErr- UnsupReq-
			RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
		LnkCap:	Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <4us, L1 <64us
			ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
			ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 2.5GT/s (ok), Width x1 (ok)
			TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Not Supported, TimeoutDis+, NROPrPrP-, LTR+
			 10BitTagComp-, 10BitTagReq-, OBFF Via message/WAKE#, ExtFmt-, EETLPPrefix-
			 FRS-, TPHComp-, ExtTPHComp-
			 AtomicOpsCap: 32bit- 64bit- 128bitCAS-
		LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
			MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
	Capabilities: [148 v1] Device Serial Number 00-e0-4c-ff-fe-c8-22-01
	Capabilities: [158 v1] Latency Tolerance Reporting
		Max snoop latency: 0ns
		Max no snoop latency: 0ns
	Capabilities: [160 v1] L1 PM Substates
		L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
			  PortCommonModeRestoreTime=30us PortTPowerOnTime=60us
			   T_CommonMode=0us LTR1.2_Threshold=0ns
	Kernel driver in use: vfio-pci
	Kernel modules: rtl8822ce
This is the output when trying to run Qemu-KVM and passing the -device 0004:01:00.0 which is the Network Card.
-device vfio-pci,host=0004:01:00.0,id=wifi: vfio 0004:01:00.0: group 6 is not viable
Please ensure all devices within the iommu_group are bound to their vfio bus driver.
It says it is not a viable group 6, but dmesg does show it being added to the group on boot:
[   19.930625] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[   20.142925] pcieport 0004:00:00.0: Adding to iommu group 6
[   25.292490] vfio-pci 0004:01:00.0: Adding to iommu group 6
Running virsh nodedev-list doesn’t show the PCI either to be taken control of
I hope this gives a little bit more clarity to the issue.
Kind Regards
Is it possible to reproduce the issue on Xavier NX or Xavier developer kit? So that we can set up and replicate the issue and check further. There are Key E and M slots on Xavier NX developer kit. And a PCIe x16 connector on Xavier developer kit. Please check if it is possible to share the steps and we can try it on developer kit.
Hi @DaneLLL, this has all been done on a Jetson Xavier NX development kit.
This steps will give you an idea whether the PCI devices are available to passthrough:
installing packages:
sudo apt install -y qemu qemu-kvm libvirt-daemon libvirt-clients bridge-utils virt-manager
enable libvirtd:
sudo systemctl enable --now libvirtd
check with virsh which PCI are available:
sudo virsh nodedev-list
In a normal scenario, you would see something like pci_0004_01_00_0 which correlates to domain:bus:device:function from lspci but in the case of the development kit, there are no pci devices showing up.
alternatively, you can run qemu from the command line and pass the vfio-pci with the -device option. To make this work, you first add the kernel module to /etc/modules and you should also define the ids for vfio-pci under /etc/modprobe.d/vfio.conf. You can find the id for vfio_pci by running lspci -n
modules:
vfio.conf:
I hope this helps,
Kind regards
Please share which device you are using. For testing Key E slot, we have the module intel 8265. For Key M slot, we use NVMe SSD card. Not sure if we can reproduce the failure with these devices.
Hi @DaneLLL
I’m not quite sure I understand your last reply. I’ve already pointed out I’m working on a Jetson Xavier NX development kit and I’ve sent you the lspci output showing the network card on the m.2 slot is an RTL8822CE (this is the PCIe we’re trying to passthrough).
What do you mean by “not sure if we can reproduce the failure with these devices”? Have you tried doing the passthrough? Has it worked with the Intel 8265? is it showing up when you run sudo virsh nodedev-list?
We don’t have much experience about this use-case and would need more information. Sorry that we don’t ask appropriate questions.
Please check and confirm if the following steps are good for checking the issue:
  1. Flash Jetpack 4.6.3 to Xavier NX developer kit
  2. Insert Intel 8265 to Key E slot and boot up
  3. installing packages:
  4. enable libvirtd:
  5. check with virsh which PCI are available:
