I’m testing the PCIe communication between two Xavier(Endpoint & Rootport system), in that I’m facing an issue.
Issue: Unable to access the Rootport system and getting the error message continuously in Rootport systems
[ 83.280350] pcieport 0005:00:00.0: AER: Corrected error received: id=0000
[ 83.280375] pcieport 0005:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0000(Receiver ID)
[ 83.280595] pcieport 0005:00:00.0: device [10de:1ad0] error status/mask=00000001/0000e000
[ 83.280773] pcieport 0005:00:00.0: [ 0] Receiver Error (First)
I followed the procedure from the following link to check the PCIe endpoint in Xavier board
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide%2Fxavier_PCIe_endpoint_mode.html%23wwpID0E0WD0HA
Step1: I flashed R32.4.3 with ODMDATA=0x09191000 in one Xvaier board for the PCIe endpoint system
Step2: In another Xavier board, I flashed the same R32.4.3 with ODMDATA=0x09190000 for the PCIe root port system
Step3: Connected PCIe cable between two Xavier board. In this cable TX & RX are swapped and we removed 12V and 3.3V in one end.
Step4: Booted the endpoint Jetson system and checked the clock mux selects NVHS_SLVS_REFCLK_P/N for endpoint system
root@nvep-desktop:/home/nvep# grep 253 /sys/kernel/debug/gpio
gpio-253 ( |pex-refclk-sel-high ) out hi
Step5: Followed below commands to enable the PCIe endpoint mode
root@nvep-desktop:/home/nvep# cd /sys/kernel/config/pci_ep/
root@nvep-desktop:/sys/kernel/config/pci_ep# mkdir functions/pci_epf_nv_test/func1
root@nvep-desktop:/sys/kernel/config/pci_ep# echo 0x10de > functions/pci_epf_nv_test/func1/vendorid
root@nvep-desktop:/sys/kernel/config/pci_ep# echo 0x0001 > functions/pci_epf_nv_test/func1/deviceid
root@nvep-desktop:/sys/kernel/config/pci_ep# ln -s functions/pci_epf_nv_test/func1 controllers/141a0000.pcie_ep/
root@nvep-desktop:/sys/kernel/config/pci_ep# echo 1 > controllers/141a0000.pcie_ep/start
Step5: Booted the Rootport Jetson system and getting the following error continuously and only sometimes we are able to access the device through ssh
[ 83.371942] pcieport 0005:00:00.0: AER: Corrected error received: id=0000
[ 83.371963] pcieport 0005:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0000(Receiver ID)
[ 83.372183] pcieport 0005:00:00.0: device [10de:1ad0] error status/mask=00000001/0000e000
[ 83.372362] pcieport 0005:00:00.0: [ 0] Receiver Error (First)
[ 83.382454] pcieport 0005:00:00.0: AER: Corrected error received: id=0000
[ 83.382473] pcieport 0005:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0000(Receiver ID)
[ 83.382685] pcieport 0005:00:00.0: device [10de:1ad0] error status/mask=00000001/0000e000
[ 83.382848] pcieport 0005:00:00.0: [ 0] Receiver Error (First)
root@nvrp-desktop:/home/nvrp# setpci -s 0005:01:00.0 COMMAND=0x02
root@nvrp-desktop:/home/nvrp# lspci -v
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad2 (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 35
Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
I/O behind bridge: 00000000-00000fff
Memory behind bridge: 40000000-400fffff
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Root Port (Slot-), MSI 00
Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
Capabilities: [100] Advanced Error Reporting
Capabilities: [148] #19
Capabilities: [158] #26
Capabilities: [17c] #27
Capabilities: [190] L1 PM Substates
Capabilities: [1a0] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
Capabilities: [2a0] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: [2d8] #25
Capabilities: [2e4] Precision Time Measurement
Capabilities: [2f0] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
Kernel driver in use: pcieport0001:01:00.0 SATA controller: Marvell Technology Group Ltd. Device 9171 (rev 13) (prog-if 01 [AHCI 1.0])
Subsystem: Marvell Technology Group Ltd. Device 9171
Flags: bus master, fast devsel, latency 0, IRQ 564
I/O ports at 100010 [size=8]
I/O ports at 100020 [size=4]
I/O ports at 100018 [size=8]
I/O ports at 100024 [size=4]
I/O ports at 100000 [size=16]
Memory at 1230010000 (32-bit, non-prefetchable) [size=512]
Expansion ROM at 1230000000 [disabled] [size=64K]
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [70] Express Legacy Endpoint, MSI 00
Kernel driver in use: ahci0005:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 39
Memory behind bridge: 40000000-401fffff
Prefetchable memory behind bridge: 0000001c00000000-0000001c000fffff
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [b0] MSI-X: Enable- Count=8 Masked-
Capabilities: [168] #26
Capabilities: [190] #27
Capabilities: [1c0] L1 PM Substates
Capabilities: [1d0] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
Capabilities: [2d0] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: [308] #25
Capabilities: [314] Precision Time Measurement
Capabilities: [320] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
Kernel driver in use: pcieport0005:01:00.0 RAM memory: NVIDIA Corporation Device 0001
Flags: fast devsel, IRQ 255
Memory at 1f40100000 (32-bit, non-prefetchable) [disabled] [size=64K]
Memory at 1c00000000 (64-bit, prefetchable) [disabled] [size=128K]
Memory at 1f40000000 (64-bit, non-prefetchable) [disabled] [size=1M]
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit-
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [1b8] Latency Tolerance Reporting
Capabilities: [320] Vendor Specific Information: ID=0003 Rev=1 Len=054 <?>
Step6: Writing shared memory in endpoint & reading it in the root port system and viceversa
root@nvep-desktop:~# dmesg|grep pci_epf_nv_test
[ 46.499526] pci_epf_nv_test pci_epf_nv_test.0: BAR0 RAM phys: 0x436614000
[ 46.499535] pci_epf_nv_test pci_epf_nv_test.0: BAR0 RAM IOVA: 0xffff0000
[ 46.499559] pci_epf_nv_test pci_epf_nv_test.0: BAR0 RAM virt: 0xffffff8008007000
[Writting in endpoint]
root@nvep-desktop:~# busybox devmem 0x436614000 32 0x12345678
[Reading in rootport]
root@nvrp-desktop:~# busybox devmem 0x1f40100000
0x12345678
[Writting in rootport]
root@nvrp-desktop:~# busybox devmem 0x1f40100004 32 0x09876543
[Reading in endpoint]
root@nvep-desktop:~# busybox devmem 0x436614004
0x09876543
Note:
Enabled CONFIG_PCIEASPM_PERFORMANCE=y in both Jetson Endpoint & Rootport system, still the issue is coming.
Sometimes only we can able to access the root port. Remaining times we are unable to access the root port, the error message only coming continuously
Tested two different PCIe cable and getting the same results:
1.removed only 12V Power
2.removed both 3.3V and 12V Power
Hope for the better guidance
Regards,
Bala
