Hi omp,
where do the values “0x10de, 0x0001” come from?
I do “lspci -v” command, the infomation be printed as follow:
root@we-desktop:/home/we# lspci -v
0000:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 33
Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] Express Root Port (Slot-), MSI 00
Capabilities: [b0] MSI-X: Enable- Count=8 Masked-
Capabilities: [100] Advanced Error Reporting
Capabilities: [148] #19
Capabilities: [168] #26
Capabilities: [190] #27
Capabilities: [1c0] L1 PM Substates
Capabilities: [1d0] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
Capabilities: [2d0] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: [308] #25
Capabilities: [314] Precision Time Measurement
Capabilities: [320] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
Kernel driver in use: pcieport
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad2 (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 35
I/O behind bridge: 00000000-00000fff
Memory behind bridge: 40000000-400fffff
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
Capabilities: [158] #26
Capabilities: [17c] #27
Capabilities: [190] L1 PM Substates
Capabilities: [1a0] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
Capabilities: [2a0] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: [2d8] #25
Capabilities: [2e4] Precision Time Measurement
Capabilities: [2f0] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
0003:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad2 (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 37
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 39
It’s print out four PCI bridges, for example 0005:00:00.0 PCI bridge, the deviceid is “0x1ad0” is it correct ? and there are three Vendor Specific Information ID value 0002, 0001, 0004 which one is the deviceid ? I’m confused. Please help me, Thanks.
