PCIe EP/RP speedtest for virtual network and DMA
Hello, any support on this topic, especially for the DMA speed test?
I followed this topic, but can’t figure out how to see the channel, size, etc. fields under /sys/kernel/debug/pcie@141a0000/ on the EP side. They don’t appear.
To attempt to solve this, I added these fields to tegra_defconfig:
CONFIG_PCIE_TEGRA=y
CONFIG_PCIE_RP_DMA_TEST=y
CONFIG_PCIE_TEGRA_DW=y
CONFIG_PCIE_TEGRA_HOST=y
CONFIG_PCIE_TEGRA_DW_DMA_TEST=y
Then I modified the source by defining CONFIG_PCIE_TEGRA_DW_DMA_TEST in these files:
nvidia/drivers/pci/host/pcie-tegra-dw.c
nvidia/drivers/pci/dwc/pcie-tegra.c
Then, I re-compiled kernel & re-flashed both my Orin AGX EP and Xavier NX RP.
I then boot both EP and RP. lspci enumeration, memory-mapped data transfer with busybox , and virtual Ethernet-over-PCIe still work properly.
On EP, under /sys/kernel/debug/pcie@141a0000/, I now see the following:
apply_flr
apply_sbr
aspm_state_cnt
ep_rid
perf_test
target_speed
apply_pme_turnoff
apply_speed_change
dma_size
flr_rid
sanity_test
However: When I attempt the DMA speedtest with cat perf_test, I get the following error in dmesg
[  326.096457] tegra194-pcie 14100000.pcie: edma_submit_direct_tx: DD WR CH: 0 TO
[  326.103966] tegra194-pcie 14100000.pcie: perf_test: DD WR, SZ: 267386880 B CH: 0 failed
[  326.496852] irq 65: nobody cared (try booting with the "irqpoll" option)
[  326.503794] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G           OE     5.10.120-tegra #1
[  326.503799] Hardware name: Unknown Jetson AGX Orin Developer Kit/Jetson AGX Orin Developer Kit, BIOS 4.1-33958178 08/01/2023
[  326.503806] Call trace:
[  326.503837]  dump_backtrace+0x0/0x1d0
[  326.503845]  show_stack+0x30/0x40
[  326.503870]  dump_stack+0xd8/0x138
[  326.503876]  __report_bad_irq+0x58/0xe4
[  326.503893]  note_interrupt+0x2dc/0x3a0
[  326.503913]  handle_irq_event_percpu+0x90/0xa0
[  326.503922]  handle_irq_event+0x50/0xf0
[  326.503932]  handle_fasteoi_irq+0xc0/0x170
[  326.503940]  generic_handle_irq+0x40/0x60
[  326.503947]  __handle_domain_irq+0x70/0xd0
[  326.503953]  gic_handle_irq+0x68/0x134
[  326.503957]  el1_irq+0xd0/0x180
[  326.503973]  __bitmap_and+0x1c/0x80
[  326.503983]  rebalance_domains+0x298/0x3a0
[  326.503989]  run_rebalance_domains+0x54/0x80
[  326.503993]  __do_softirq+0x140/0x3e8
[  326.504006]  irq_exit+0xc0/0xe0
[  326.504012]  __handle_domain_irq+0x74/0xd0
[  326.504016]  gic_handle_irq+0x68/0x134
[  326.504021]  el1_irq+0xd0/0x180
[  326.504038]  tick_nohz_idle_exit+0x6c/0xc0
[  326.504042]  do_idle+0x188/0x270
[  326.504047]  cpu_startup_entry+0x30/0x70
[  326.504059]  rest_init+0xdc/0xe8
[  326.504075]  arch_call_rest_init+0x18/0x20
[  326.504080]  start_kernel+0x500/0x538
[  326.504085] handlers:
[  326.506438] [<0000000080b2cb9f>] tegra_pcie_rp_irq_handler threaded [<0000000072a6e636>] tegra_pcie_rp_irq_thread
[  326.517023] [<00000000daf0649b>] pcie_pme_irq
[  326.521517] [<00000000d940327e>] aer_irq threaded [<00000000445996a2>] aer_isr
[  326.528966] Disabling IRQ #65
Subsequent runs of cat perf_test yield this in dmesg:
[ 1629.245230] tegra194-pcie 14100000.pcie: perf_test: DD WR, CH: 0 SZ: 267386880 B, time: 4795902405 ns
[ 1634.252759] tegra194-pcie 14100000.pcie: edma_submit_direct_rx: DD RD CH: 0 TO
[ 1634.260248] tegra194-pcie 14100000.pcie: perf_test: DD RD, SZ: 267386880 B CH: 0 failed
[ 1713.797575] tegra194-pcie 14100000.pcie: perf_test: DD WR, CH: 0 SZ: 267386880 B, time: 4819465563 ns
[ 1718.989272] tegra194-pcie 14100000.pcie: edma_submit_direct_rx: DD RD CH: 0 TO
[ 1718.996768] tegra194-pcie 14100000.pcie: perf_test: DD RD, SZ: 267386880 B CH: 0 failed
[ 1768.293684] tegra194-pcie 14100000.pcie: perf_test: DD WR, CH: 0 SZ: 267386880 B, time: 4769931990 ns
[ 1773.517746] tegra194-pcie 14100000.pcie: edma_submit_direct_rx: DD RD CH: 0 TO
[ 1773.525247] tegra194-pcie 14100000.pcie: perf_test: DD RD, SZ: 267386880 B CH: 0 failed
